Best way to increase brake light brightness
#2257948
02/22/17 10:57 PM
02/22/17 10:57 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
My 68 Dart brake lights, while they work great, aren't as bright as I'd like them to be. How can I remedy this, without melting the housing or lenses? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Best way to increase brake light brightness
[Re: MI_Custumz]
#2257960
02/22/17 11:22 PM
02/22/17 11:22 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Do you have to add anything else for LED to work, or are they plug and play? Typically you need to change to an electrical flasher since the there is not enough load going through the LEDs to operate an original-style mechanical flasher. These can be found on the shelf at a local parts store.
[Re: Kern Dog]
#2257980
02/23/17 12:08 AM
02/23/17 12:08 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
You could disassemble the housings and repaint the insides with silver paint. Actually white paint works the best. I did it to mine and the results were amazing! Do a Google search on this...
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: Plum440]
#2257986
02/23/17 12:16 AM
02/23/17 12:16 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You could disassemble the housings and repaint the insides with silver paint. Actually white paint works the best. I did it to mine and the results were amazing! Do a Google search on this... Really? The lights didn't get a pink hue?
[Re: GTSDart340]
#2258016
02/23/17 01:12 AM
02/23/17 01:12 AM
Posts: 18,160 Mass
DAYCLONA
Mass
My 68 Dart brake lights, while they work great, aren't as bright as I'd like them to be. How can I remedy this, without melting the housing or lenses? Thanks! I'd contact Digi-Tails if your interested in LED taillights, while only the 69 Dart is currently available they are always increasing their list of applications, plus you can make a request to see if a custom application can be made for your vehicle
[Re: Sixpak]
#2258044
02/23/17 01:52 AM
02/23/17 01:52 AM
RapidRobert
cleaned up connections, good (or better) grounds, clean lenses... this would be my first action.
[Re: GTSDart340]
#2258096
02/23/17 05:43 AM
02/23/17 05:43 AM
Posts: 43,364 Bend,OR USA
Cab_Burge
Two things make the lights dim on cars, low voltage(high resistance in the feed wires) and bad grounds(high resistance back to the battery ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) I would check the voltage to the light socket and then check the resistance to the ground with a good Volt Ohm meter ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) If it has low voltage to the socket work back in the wiring harness towards the brake light switch if it has high resistance in the grounds clean them up so it doesn't ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: DAYCLONA]
#2258105
02/23/17 10:02 AM
02/23/17 10:02 AM
Posts: 11,084 Berlin, N.J.
abodyjoe
Berlin, N.J.
My 68 Dart brake lights, while they work great, aren't as bright as I'd like them to be. How can I remedy this, without melting the housing or lenses? Thanks! I'd contact Digi-Tails if your interested in LED taillights, while only the 69 Dart is currently available they are always increasing their list of applications, plus you can make a request to see if a custom application can be made for your vehicle good guys there.. they are right around the corner from me.. have them in out 70 dart..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: GTSDart340]
#2258109
02/23/17 10:28 AM
02/23/17 10:28 AM
abodyjoe
Berlin, N.J.
this is from a lighting expert on another site i'm on.. Though they are spendy, the best bulb you can use in place of 1157 is a 3496. You can get them from your local Honda dealer. Part number is 34906-SL0-A01. It draws the same amount of current as 1157, but is much more efficient. It produces 43 candlepower on the bright (brake or turn) filament, and 3.5 candlepower on the dim (tail or parking) filament. It also has a nickel-plated base that is much more corrosion resistant than the plain brass base of an 1157, so it's less likely to stick in the socket. another possible option: https://www.amazon.com/dp/B00HWS7XGW/ref=asc_df_B00HWS7XGW4848938?smid=ATVPDKIKX0DER&tag=shopzilla0d-20&ascsubtag=shopzilla_rev_275-20;14878516480879371725210070302008005&linkCode=df0&creative=395093&creativeASIN=B00HWS7XGW
[Re: GTSDart340]
#2258110
02/23/17 10:30 AM
02/23/17 10:30 AM
abodyjoe
Berlin, N.J.
some other good info from the same guy...
Bulbs Original equipment bulbs on most pre-'72 cars was as follows:
1034: dual-filament park/turn and brake tail. Clear bulb for use with red rear or amber front lens.
1034A or 1034NA: dual-filament park/turn. Amber bulb for use with clear front lens.
1141 or 1073: single-filament bulb. Reversing/backup lights (and single-function—brake-only, turn-only—lights not frequently found on old Mopars).
In the early '70s, the 1034 was replaced by the 1157, the 1073/1141 by the 1156. These 1150-series bulbs put out the same amount of light, but draw slightly more current and last quite a bit longer. When changing from 1034s to 1157s, often it was (and is) necessary to replace the turn signal flasher, because the original would flash too fast if used with 1157s. Nowtimes, it's difficult to find a flasher calibrated for 1034s.
So, what to use for upgrade bulbs? Well first, here's what NOT to use: 2057s! People sometimes assume that because it's a higher number, it's a brighter bulb. No. The difference between 1157 and 2057 is in the "minor" (dim parking or tail) filament. On the 2057, the dim filament produces 2 candlepower. On the 1157, the dim filament produces 3 candlepower. The difference doesn't sound like much, but it's very large as a percentage. Both 1157 and 2057 produce 32 candlepower from the bright (brake or turn) filament.
The best replacement for 1156, 1141 and 1073 in all applications *except* reversing/backup lights is a 3497. You can get P3497 bulbs from your local Honda dealer, too. Part number is 34903-SF1-A01.
3497 produces 45 candlepower. (Yes, the 6 and the 7 in P3496 and P3497 are reversed from the 6 and the 7 in 1156 and 1157 relative to how many filaments the bulb has. This is not a typo.) The 3496 and 3497 bulbs have a life span about double that of an 1157. It is worth your time, money, and trouble to get the 3496 and 3497 from a Honda dealer rather than a parts store...the parts store items are of much poorer quality and don't last as long.
The best bulb for use in backup/reverse lights is a 796. It is a 35W halogen bulb that produces 62 candlepower, or about double the light of an 1156 and about triple the light of an 1141. The extra wattage is minor (35W vs. 28W, the wires and lenses will not notice or care) and the filament is in the right place. Neither of these compliments can be said of those 50W halogen backup bulbs you see in the parts stores! 50W is wayy too much current draw (100% overload!) for the stock wiring and switch, they produce way too much heat for safety near plastic lenses, and the filament's in the wrong place so the reflector doesn't work correctly with them. The P796s work great, and you finally get to see where you're going when backing at night.
Amber bulbs are a special case. The amber coating "steals" some of the light, so the output is lower. The bright filament inside an 1157A or 1157NA produces 32 candlepower, but what comes through the amber coating is 24 candlepower. Unfortunately, there's no amber equivalent of 3496 for use in park/turn lights that have clear lenses. The next best thing is 2357A or 2357NA, which draws the same current as an 1157 and produces 30 candlepower despite the amber coating. 2357NA (or 2357A), as well as their non-amber 2357 counterparts, are considerably less expensive than P3496, but they lack P3496's anti-corrosion nickel-plated base, and they also lack P3496's Krypton gas fill, so they tend to blacken sooner than other bulbs if used in "bright" mode for prolonged periods (e.g. using a 2357 in brake lamp service). The 2357NA or 2357A works fine in front park/turn service because turn signal service is short and intermittent, which limits bulb blackening and makes overall bulb life acceptable.
Be careful when buying any of these bulbs. A lot of the major parts outlets are switching from name-brand bulbs worth buying to 3rd-world crapola not worth its blister pack. Only one company makes quality 3496s and 3497s, for example, that is Stanley. GE and Sylvania used to supply Stanley-made 3400-series bulbs, but both marketers went to Chinese lookalikes, and then to even cruddier Chinese ones that don't even look right. That's why to buy those particular ones at the Honda store.
The '68-'71 sidemarker lamps can be made about 60% brighter with 3886x bulbs, which also fit directly in place of the 1895s and 57s used in instrument cluster lights that take the metal bayonet-base bulbs.
1972-up sidemarker lights (and a lot of the '66-up instrument cluster lights) take an all-glass wedge-base bulb, which can be upgraded with 2886x bulbs - about 75% brighter than a 194, 60% brighter than a 168.
If your car has the little turn signal indicators mounted on top of the fenders, and one or both of them no longer flash, you can either spend $3.40 apiece at Year One for a replacement bulb with a plain brass base, or you can spend $10.60 and get a 10-pack of 'em with corrosionproof nickel-plated bases.
[Re: Plum440]
#2258139
02/23/17 11:50 AM
02/23/17 11:50 AM
Posts: 1,853 South Bend
John Brown
South Bend
You could disassemble the housings and repaint the insides with silver paint. Actually white paint works the best. I did it to mine and the results were amazing! Do a Google search on this... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) White is right, or in this case, white is bright. If you're a non-believer, just ask at your local paint store what colors they have to mix together to make silver paint. You'll be surprised.
[Re: abodyjoe]
#2258143
02/23/17 11:59 AM
02/23/17 11:59 AM
John Brown
South Bend
some other good info from the same guy... Thanks.....
[Re: GTSDart340]
#2258174
02/23/17 01:10 PM
02/23/17 01:10 PM
GTSDart340
Laveen, Arizona
Thanks guys. I have always been worried about my brake lights. Getting rear ended sucks. Once I get my new overheating problem fixed, I'll get looking at this.
[Re: abodyjoe]
#2258191
02/23/17 01:56 PM
02/23/17 01:56 PM
RapidRobert
Abodyjoe, VG/comprehensive info!
