Going E85 .... Do's and Don'ts...need user feedback.
#2257369
02/21/17 08:52 PM
02/21/17 08:52 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I think we are settled on giving pump E85 a shot in S/C and S/P racing with our dragster. I like the lower engine temps from E85 in case we end up hot lapping at bracket events. We have a QFT 1295 carb that I will convert using their kit. We havent built the motor yet so CR is still up in the air but looking at 14.5 to 1 with aluminum heads.
So...E85 guys...let's hear it.
Thanks to all whom take the time to respond.
Re: Going E85 .... Do's and Don'ts...need user feedback.
[Re: Chassisman]
#2257379
02/21/17 09:02 PM
02/21/17 09:02 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why not go straight to alcohol. Most guys that make the switch in drag cars end up doing it so it would save you a few bucks.
[Re: Chassisman]
#2257398
02/21/17 09:30 PM
02/21/17 09:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't chicken out on compression.
[Re: HotRodDave]
#2257400
02/21/17 09:33 PM
02/21/17 09:33 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wow I pay around 130.00 for 54 gallons
[Re: sam64]
#2257429
02/21/17 10:31 PM
02/21/17 10:31 PM
Chassisman
Chowchilla,ca
buy a tester and always test what is coming out of the pump.here in Oklahoma it varied quite a bit,but we were just getting places that had it 3 years ago.I think I would get a 55 gallon drum and fill it when you find good E 85.when I say varied I mean 55 to 90 !! That's what I'm going to do. I have a clean 250 gallon sealed tote ....so If I go to the station and fill the tote then vacuum out the air it should stay fairly fresh and consistent.I'll buy some E98 if I can find some to bring it up to true E85.
[Re: Chassisman]
#2257452
02/21/17 11:05 PM
02/21/17 11:05 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have had no problems here in SoCal with stations that sell Pearson fuels e85, good to check it though.
My biggest suggestion would be when you start it up warm it up, get the moisture out.
If it is going to set a while drain the bowls and pump the acc. pumps into a rag. Also the pink Mp-15 carb gaskets (superformance) are good because they come off nice for carb maintenance.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2257495
02/21/17 11:58 PM
02/21/17 11:58 PM
Chassisman
Chowchilla,ca
If it is going to set a while drain the bowls and pump the acc. pumps into a rag. Also the pink Mp-15 carb gaskets (superformance) are good because they come off nice for carb maintenance. Good to know. We are sponsored by Lucas I'm working with them on a fuel conditioner additive to combat draining between racing weekends. I can get Pearson and Propel in Fresno.... Thanks
[Re: Chassisman]
#2257521
02/22/17 12:29 AM
02/22/17 12:29 AM
Posts: 1,113 Usa
A39Coronet
Usa
I would HIGHLY suggest you do not convert your carb with a kit. Those kits are one size fits all, and the likelihood of it being for your motor is extremely unlikely. Go to a dedicated E85 carb builder/converter, give them your specs, and you will have someone who can troubleshoot for you if a problem arises. I have a 1050 Dominator from Eric @ Horsepower Innovations, and it's fantastic. He's actually building me a 1000 Ultra HP right now as well.
My car doesn't run that* much cooler than on 110, but I hot lap the hell out of my car and I never have issues with heat. I like to run mine a little fatter, as I've found that the car runs tighter ET spreads.
As said above, don't start your car without getting it hot...As in the oil hot, not just the water. Unlikely to occur just by idling in the garage, so I always avoid moving it unless it's headed to the track. I don't drain my bowls hardly ever, even after three weeks, and have never had white chalk or gelling or issues. I use standard Holley blue bowl gaskets without issue.
I love it, I'll never run race fuel again.
[Re: Chassisman]
#2257624
02/22/17 04:31 AM
02/22/17 04:31 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
We have been running E85 for the last two years in our dragster. I bought a QF E85 dominator and it has been a lot of trial and error to make it work, but for now it seems to run ok with our low compression 440. We actually ran out of supplies for pump E85 here and switched to Vp and then Torco E85. Cost is about double the pump stuff. BUt the car did pick up with those fuels over pump swill, like a lot. .1-.15 over pump stuff. My understanding is the pump stuff does not get the best grade of gasoline to begin with whereas the stuff from Torco or VP gets a better gasoline base fuel. All I know is it flat out runs faster. The other suggestions here are valid. When we ran straight pump E85 starting the car when the ambiet was cold was an issue. At the Turkey race we ended up using straight pump gas to start in the am, on the Torco or Vp that is not an issue. Definitely don't start it unless you can get the oil warm. We also never drain the fuel and since switching away from pump have never had an issue. We did have it gum up once when it was on pump swill after sitting for an extended period.
[Re: Chassisman]
#2257888
02/22/17 08:48 PM
02/22/17 08:48 PM
Posts: 72 sioux falls, sd
10sec.dart
sioux falls, sd
e85 is great, I would recommend getting a afr gauge, makes tuning way easy,if you are going over 13-1 compression then you could consider e98 as an option too, you don't have to worry about gas mixtures or what kind of gas they mixed with, plus the higher octane is a plus. and like other people said I wouldn't go with a conversion kit, send the carb off to some one reputable, classic motorsports in sauk centre MN did ours and they work great, he puts them on a dyno motor to get them pretty close on the tune and make sure they work on first fire up, they take a little fine tuning to get perfect that's where the afr gauge comes in handy,
[Re: 10sec.dart]
#2257914
02/22/17 09:59 PM
02/22/17 09:59 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I think you can be successful with a conversion.... but at the cost of a trip to the racetrack these days.. I think either purchasing a carburetor or having it converted is the way to go.. I have had dealings with Mark sullens and pro systems and both have been very good... they both have completely different ideas which both returned great results.. I think five or six outings to the track. Figuring out the carburetor... You will have spent more money and more wear and tear then it's worth
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Chassisman]
#2257927
02/22/17 10:16 PM
02/22/17 10:16 PM
Chassisman
Chowchilla,ca
We already have a QFT carb. So the conversion we are looking at is this one....its supposedly very tunable. QFT did a decent job of getting us base lined with our carb when I bought it. I'll contact some of the names posted on here and talk to them. Here's QFT change over kit for their carbs https://www.quickfueltechnology.com/carb...r-m4500-hp.html
[Re: Chassisman]
#2257976
02/22/17 11:52 PM
02/22/17 11:52 PM
Posts: 1,113 Usa
A39Coronet
Usa
We already have a QFT carb. So the conversion we are looking at is this one....its supposedly very tunable. QFT did a decent job of getting us base lined with our carb when I bought it. I'll contact some of the names posted on here and talk to them. Here's QFT change over kit for their carbs https://www.quickfueltechnology.com/carb...r-m4500-hp.html So are the boosters for a 400ci or a 540? How about the IAC and other orifices? For $340 you can have it custom converted for your cam, for your cubes, for your heads, instead of a one size fits all kit. Just because QF can make it run, doesn't mean it's right. I'd hate to see someone buy a garbage conversion kit and have issues only to write off corn completely.
[Re: Chassisman]
#2258206
02/23/17 02:35 PM
02/23/17 02:35 PM
Al_Alguire
Las Vegas
Who does this work for $340?(I see the kit price and assume by the response you are referring to having someone do the work for that $$) If they are out there I am unaware of them. Last I checked Sullens and HP Innovations were both $600 or more. Just curious..
