Prestolite Distributor Shaft #2256748
02/20/17 07:07 PM
02/20/17 07:07 PM
MoparHonda Offline OP
I have a Prestolite distributor in a 440/6 engine. We suspect the shaft is slightly bent because the shaft does not turn easily all the way around, it seems to hang up/drag at the same point in every revolution.
My local machine shop says they do not have the equipment to determine of the shaft is bent or not.
Any suggestions? Does anyone know where I could get a good, straight shaft?
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256766
02/20/17 07:47 PM
02/20/17 07:47 PM
I would undo it & a visual & spin it in your drill press. Ebay might be a source.
Re: Prestolite Distributor Shaft [Re: RapidRobert] #2256792
02/20/17 08:42 PM
02/20/17 08:42 PM
Thank you, RapidRobert.
I suspect the bend, if it is indeed bent, may be too small to see on a drill press.
I'll try e-bay, any idea what shafts will interchange with this one?
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256797
02/20/17 08:46 PM
02/20/17 08:46 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Take it apart and clean everything,it is pretty hard to bend the 1/2" diameter shaft,especially on the bottom end,possible on the top where the cam is located.Regardless it's an easy fix,I've been doing distributors a long time and I can only recall one and that was on the top and dropped on the cam.And on another note I would be a little skeptical of any machine shop that said they couldn't check it. twocents
Re: Prestolite Distributor Shaft [Re: 62maxwgn] #2256825
02/20/17 09:30 PM
02/20/17 09:30 PM
Thank you for your reply. Agreed, it would be hard to bend the shaft, if this one is bent, it's by a very small amount, just enough to cause drag at one point when turning it.
I've already had it apart and cleaned it. I also replaced the bushings.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256833
02/20/17 09:47 PM
02/20/17 09:47 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Re: Prestolite Distributor Shaft [Re: srt] #2256836
02/20/17 09:51 PM
02/20/17 09:51 PM
Thank you, SRT, I'll contact these people if no one else has any suggestions.
They say 4-5 weeks for a rebuild.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256838
02/20/17 09:54 PM
02/20/17 09:54 PM
what bushings did you use & did they require reaming? were they worn before, shaft had too much radial play (but no binding) & now after replaceing them they are binding?
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256841
02/20/17 09:59 PM
02/20/17 09:59 PM
RapidRobert, since I already had the thing apart for cleaning and inspection, I went ahead and replaced the bushings, no idea how many miles were on this.....
I used the same oilite bushings as were on it, the new bushings were about a 1/4 inch longer than the original bushings. No reaming required, they just pressed right in.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256844
02/20/17 10:03 PM
02/20/17 10:03 PM
the reaming would be for the bushing ID once installed (if needed depending on the bushings used). are we on the same page? EDIT on the clocking where it ain't binding is it loose/tight/just right?
Re: Prestolite Distributor Shaft [Re: RapidRobert] #2256859
02/20/17 10:26 PM
02/20/17 10:26 PM
The ID of the new bushings was the same as the old.
The shaft spins freely, except for 12 0'clock to 1 0'clock, where it has some resistance/binding to spinning. I can easily turn it thru the binding/resistance with my hand.
Yes, we're on the same page.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256865
02/20/17 10:36 PM
02/20/17 10:36 PM
Alright we're good. Grainger has an adjustable 15/32-17/32 straight flute reamer for $20 some dollars (I have one). One of the bushings is likely tilted a bit. for the price that would be my suggestion.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256866
02/20/17 10:36 PM
02/20/17 10:36 PM
Good, thank you, I'll get one.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256874
02/20/17 10:58 PM
02/20/17 10:58 PM
it is a 4LGR7 $20
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2256945
02/21/17 01:08 AM
02/21/17 01:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One other thing,do you have any end pay at all ? If the collar is not actually actually flat on the top side it will give you the indication the there is a slight bind.
Re: Prestolite Distributor Shaft [Re: 62maxwgn] #2257128
02/21/17 01:08 PM
02/21/17 01:08 PM
moparx Offline
moparx  Offline
if your machine shop "doesn't have the equipment" to check the shaft to see if it's bent, i would get another shop for any work you need done !
beer
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2257158
02/21/17 02:05 PM
02/21/17 02:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it was me, I'd run it and let the shaft/bushings "self clearance".
Re: Prestolite Distributor Shaft [Re: John_Kunkel] #2257164
02/21/17 02:15 PM
02/21/17 02:15 PM
How "tight" is the binding?
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2257180
02/21/17 02:58 PM
02/21/17 02:58 PM
Thank you, all.
I didn't notice any end play and I think the collar is flat on the end, but I can double check that.
The binding is just snug, I can turn it thru the binding spot by hand, it just does not turn freely.
Re: Prestolite Distributor Shaft [Re: MoparHonda] #2257391
02/21/17 09:23 PM
02/21/17 09:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What John K said! twocents Usually when the collar is removed the roll pin will only go back one way,the collar turned 180* it isn't very likely,if it does and the holes are off the slightest amount it may give you what you are experiencing.
