Ammeter to volt meter conversion #2255942
02/19/17 12:55 PM
02/19/17 12:55 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
In my other wiring post, I have my problem traced to a recurring ammeter problem so I think I need to eliminate the problem. Has anyone used the amp to volt conversion kit from Year One? Is there a better/cheaper one anyone else sells? I am terrible doing searches on past threads here and I'm sure there have been several discussion. Anyone have a link? Thanks.
Re: Ammeter to volt meter conversion [Re: fastmark] #2255952
02/19/17 01:18 PM
02/19/17 01:18 PM
None
71rm23 Offline
71rm23  Offline
None
Fastmark-When I had my cluster restored, I had them put in a volt meter and it's a solid state. The only thing I did was take the wires going it, cut the ends, soldered a splice to the red and black, then heat shrink them.
Re: Ammeter to volt meter conversion [Re: fastmark] #2255971
02/19/17 02:00 PM
02/19/17 02:00 PM
Andrewh Offline
Andrewh  Offline
Re: Ammeter to volt meter conversion [Re: 71rm23] #2255986
02/19/17 02:30 PM
02/19/17 02:30 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Where did you gets the parts?
Re: Ammeter to volt meter conversion [Re: fastmark] #2256171
02/19/17 06:59 PM
02/19/17 06:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Ammeter to volt meter conversion [Re: John_Kunkel] #2256182
02/19/17 07:33 PM
02/19/17 07:33 PM
BDW Offline
BDW  Offline
Originally Posted By John_Kunkel
This one is cheap and easy to install.
http://www.ebay.com/itm/Portable-Waterpr...r-/122025200632
Thx for the link, been looking for something small enough to mount in the ashtray
Re: Ammeter to volt meter conversion [Re: BDW] #2256191
02/19/17 08:00 PM
02/19/17 08:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This what I use...that is daytona beach sand on the floor mat. Came from camping world, it is how I monitor my battery.
Re: Ammeter to volt meter conversion [Re: John_Kunkel] #2256730
02/20/17 06:22 PM
02/20/17 06:22 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
any pics of this installed in the dash?
Re: Ammeter to volt meter conversion [Re: fastmark] #2257023
02/21/17 05:19 AM
02/21/17 05:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I could not find one to fit in my dash real well. So I put it right where my ashtray was. I dont smoke so it was no big deal to me. Ron
Re: Ammeter to volt meter conversion [Re: fastmark] #2257041
02/21/17 09:11 AM
02/21/17 09:11 AM
None
71rm23 Offline
71rm23  Offline
None
I had the place do it where I sent my cluster into.
Re: Ammeter to volt meter conversion [Re: fastmark] #2257110
02/21/17 12:27 PM
02/21/17 12:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I sent my cluster to InstrumentSpecialties. They did the volt meter conversion as part as the resto. I retained the amp meter face however it works as the voltmeter.
Abe Lincoln
Re: Ammeter to volt meter conversion [Re: dart4forte] #2257225
02/21/17 04:24 PM
02/21/17 04:24 PM
None
71rm23 Offline
71rm23  Offline
None
EXACTLY what I did
Re: Ammeter to volt meter conversion [Re: fastmark] #2257490
02/21/17 11:53 PM
02/21/17 11:53 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I made my own gauge by gutting a small 2" voltmeter and adapting it to my stock Ammeter....even had a custom face decal made up
1MYTGTX
Re: Ammeter to volt meter conversion [Re: 1MYTGTX] #2257531
02/22/17 12:39 AM
02/22/17 12:39 AM
^^^ trick! excellent
Re: Ammeter to volt meter conversion [Re: fastmark] #2257649
02/22/17 09:50 AM
02/22/17 09:50 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Wow. That's nice. I see a market for that. Let's look at the back side. What volt gauge did you use?
Re: Ammeter to volt meter conversion [Re: fastmark] #2257876
02/22/17 08:11 PM
02/22/17 08:11 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Thanks! I used an Autogauge 2356. Had the decal made up by Whitegauges.net
See this thread on DC.com
http://www.dodgecharger.com/forum/index.php/topic,108698.0.html
1MYTGTX
Re: Ammeter to volt meter conversion [Re: fastmark] #2258779
02/24/17 04:04 PM
02/24/17 04:04 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I can see adding a volt meter, but don't get why people replace an ammeter with a volt meter. To me, the ammeter is the quickest way to spot a problem with the charging system, or for visualizing which systems, when turned on, are causing a current draw that the charging system can't satisfy...
Re: Ammeter to volt meter conversion [Re: fastmark] #2259122
02/25/17 10:15 AM
02/25/17 10:15 AM
Australia
dodgy Offline
dodgy  Offline
Australia
hi all, done this mod to my aussie valiant, not real hard to do, like others have said I used a cheep sunpro I think gauge and adapted it to the cluster and had a decal made to suit, heres a link.
http://www.hemi6pack.com/forum/showthrea...5708#post835708
Re: Ammeter to volt meter conversion [Re: Sixpak] #2259206
02/25/17 12:45 PM
02/25/17 12:45 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
40 year old wires, loose and cooroded connections, added electrical demand from today's modern electronic ignitions, electric fuel pumps, electric fans, GPS devices plugged into power outlets, aftermarket stereo systems with amps, etc and upgraded alternators putting out double the original amperage....
That's why
Lots of cars have suffered electrical fires from under the dash. Even a bone stock car, if you drained the battery and jump it, is now pushing 65 amps through a tiny 10 ga wire that passes through the firewall twice.
Bone stock restored car with old points ignition, and fresh clean wire harnesses and good connectors and the stock alternator, then you can go ahead and keep your amp gauge.
**Photobucket sucks**
Re: Ammeter to volt meter conversion [Re: 70Cuda383] #2259210
02/25/17 12:50 PM
02/25/17 12:50 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Oh, and since it takes the voltage regulator and alternator a second to recover from a large amp draw, and most likely not recover at all from idle, you can see the same information on your voktgage that the amp gauge was telling you. >12? That's the same as slightly over 0 on amp gauge. 12 is 0 and <12 is discharge.
40+ amp load from electric fan kicking on, and a sustained 30 amp draw, at idle you can watch the bolts drop to 10. That's a huge discharge. Blip the throttle to bring RPM up and you can see the bolts come back up, so you know everything is working
