Hey All, My Tow rig is a 2001 Ram 3500 4x4 with 5.9 mag and 46re Tranny. I lost reverse on a fairly fresh transmission. I removed the pan and found thè reverse servo is stuck up inside the bore. So either the seal went or the common servo crack.. So the question looming in my mind is: All of the procedures I found online indicate that you must remove the Transfer case and OD Unit from the Transmission in order to remove the pin from the reverse arm so that you can remove the reverse servo from the bore.. Is there an easier way? I was thinking maybe remove adjuster from the arm and removing it from the band, maybe still not enough room to get the servo out.. Please enlighten me on an easier way! Thanks
