Which ECU for Edelbrock Pro Flo intake? #2255689
02/18/17 10:50 PM
02/18/17 10:50 PM
AndyF Offline OP
AndyF  Offline OP
I think we have a few guys on the board using the Pro Flo. Just wondering what ECU you are using. I'm in the process of getting the Holley HP setup which I think will work with the Edelbrock throttle body. I also have the Holley dual sync distributor.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2255714
02/18/17 11:24 PM
02/18/17 11:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Any good aftermarket EFI ECU will work fine with that manifold. The Holley HP or the FAST XFI, or MS.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2255721
02/18/17 11:34 PM
02/18/17 11:34 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had a guy bring me a sbc version of the pro flo that no one locally could fix for him. It was a complete system with edelbrock ecu. It had all sorts of idle issues, acceleration issues, starting issues etc... The ECU was a "locked" rebranded version of an EFI technologies ecu. I was locked out of to many parameters, so I had him upgrade to the unlocked software version. The unlocked version is a very capable, yet complicated system. After being able to see and alter what I needed the car ran great MOST of the time. It had intermittent stumbles and idle flaring.
The problem was continually failing TPS sensors. It turned out to be the throttle shaft on the throttle body is a touch to long, and it would side load and eventually kill the TPS sensors (3 before actually finding the cause). If you have or are going to use the edelbrock throttle body, check this!
He actually put a Holley hp ECU on the car with the same intake set up a year or so ago. His brother uses a Dominator system and had him switch over because he liked the software and logging so much more than the Edelbrock. Happy as a clam with this set up, and he is VERY picky about driveability. He also uses the dual sync.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: Mopar_Rich] #2255725
02/18/17 11:36 PM
02/18/17 11:36 PM
ct
jkgtx Offline
jkgtx  Offline
ct
using a megasquirt ms3x learning curve for sure,not as user friendly as many others using jeep cam sensor,36-1 crank wheel,80b inj.couple small turbos hope to get some tuning on street this spring
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2255810
02/19/17 01:35 AM
02/19/17 01:35 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been very happy with the megasquirt stuff. It has tons and tons of features at a good price point. With that money savings comes a little more labor on setup but there is almost nothing you can't do with an MS3X, or MS3Pro. My homebuilt ECU is coming up on two years old now.
68 Barracuda Formula S 340
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2255956
02/19/17 01:21 PM
02/19/17 01:21 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Wish they made that intake for max wedge heads !!!
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2255970
02/19/17 01:59 PM
02/19/17 01:59 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I'm a big fan of Motec, but I know the price point of their stuff isn't for everyone. You could run that engine nicely though with a Haltech or SDS system as well.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: Mopar_Rich] #2255975
02/19/17 02:08 PM
02/19/17 02:08 PM
AndyF Offline OP
AndyF  Offline OP
Hi Rich, have you had any experience with the Edelbrock system? I think I'll most likely use the Holley to work with this intake but was just wondering.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: AndyF] #2256127
02/19/17 05:55 PM
02/19/17 05:55 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes. I have had several customers use that intake with good results on stock style heads.
Re: Which ECU for Edelbrock Pro Flo intake? [Re: Stanton] #2256141
02/19/17 06:14 PM
02/19/17 06:14 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
Wish they made one for low deck!
Re: Which ECU for Edelbrock Pro Flo intake? [Re: moparlulu] #2256198
02/19/17 08:14 PM
02/19/17 08:14 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
True,that and an RB spacer option would have been a more lucrative investment.
RT
