deck finish difference for MLS head gaskets #2255782
02/19/17 12:52 AM
02/19/17 12:52 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What's the difference in deck finishes between regular head gaskets and MLS head gaskets? And why?
Re: deck finish difference for MLS head gaskets [Re: Stanton] #2255796
02/19/17 01:11 AM
02/19/17 01:11 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
In the old days the cutters left little grooves and everyboy said that's fine it helps it grip. Today everybody wants MLS gaskets and Cometic says they want a finish of 50RA or smoother.
2011 Drag Pak Challenger
Re: deck finish difference for MLS head gaskets [Re: rickseeman] #2255801
02/19/17 01:19 AM
02/19/17 01:19 AM
Cab_Burge Online work
Cab_Burge  Online Work
iagree thumbs
Re: deck finish difference for MLS head gaskets [Re: Stanton] #2256006
02/19/17 03:09 PM
02/19/17 03:09 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
So 50ra is like a "ground" finish versus a "cut" finish ??
So using MLS gaskets definitely can't be used on a cut deck?
Here's a bit of a dilemma ... what would you do with a cut deck but out-of-the-box aftermarket aluminum heads that have the smooth surface ??
Re: deck finish difference for MLS head gaskets [Re: Stanton] #2256029
02/19/17 03:45 PM
02/19/17 03:45 PM
Use a Fel Pro permatorque composition head gasket twocents
Or have the block resurfaced,refinished, for the 50RA finish shruggy
Copper head gaskets need a fine finish like the MLS head gaskets do thumbs
Re: deck finish difference for MLS head gaskets [Re: Stanton] #2256061
02/19/17 04:32 PM
02/19/17 04:32 PM
Lewiston, ID.
screemindemon Offline
Lewiston, ID.
I used MLS gaskets on my 416 stroker engine in my drag car, couldn't get them to seal, leaked antifreeze on both sides. Called the manufacturer, was told to re-torque them, which I did, no change. Talked to my engine machinist, he said he had many customers using them and had never had any problems. He also said that different alloys will cut differently, even using the same cutters. You could see the ridge marks on the gaskets when I pulled the heads. Went to Fel-Pro severe duty gaskets, have had no problems whatsoever.
