73 external balanced 340 #2255452
02/18/17 12:35 PM
02/18/17 12:35 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
I have a 73 340 external balanced, I put on the solid sfi flex plate for external balanced engine. My question is do I use the weighted torque converter with this, or does this flex plate take place of having a weighted converter.
Re: 73 external balanced 340 [Re: dartphil] #2255465
02/18/17 01:11 PM
02/18/17 01:11 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Unless the flexplate is cut out or weighted to balance,you would still need the counterbalanced/weighted converter.
RT
Re: 73 external balanced 340 [Re: RTSrunner] #2255474
02/18/17 01:34 PM
02/18/17 01:34 PM
I would do whatever you need to do/swap to be able to run a "regular" internally balanced type converter. that way you can get a good aftermarket converter right now & if you swap it out in the future you dont have to deal with the balance issue & I think the HP aftermarket ones are internally balanced??
Re: 73 external balanced 340 [Re: dartphil] #2255492
02/18/17 02:21 PM
02/18/17 02:21 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
There were 2 choices of the sfi flex plate, one for internal balance and one for external balanced. The difference between the two is the external balanced one has a moon shape cut out whereas the intrenal one has no cutout.
Re: 73 external balanced 340 [Re: dartphil] #2255497
02/18/17 02:36 PM
02/18/17 02:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The aftermarket flex plate with the cut out is so you can run a converter with out the weights. The factory puts the weights on the converter and uses a standard flex plate.
Re: 73 external balanced 340 [Re: mopars4ever] #2255531
02/18/17 04:17 PM
02/18/17 04:17 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Thanks for the help
Re: 73 external balanced 340 [Re: dartphil] #2257922
02/22/17 10:09 PM
02/22/17 10:09 PM
Earth
Rob C Offline
Rob C  Offline
Earth
FWIW, that year 340 has a unique balance.
Re: 73 external balanced 340 [Re: Rob C] #2257939
02/22/17 10:38 PM
02/22/17 10:38 PM
Does B&M have more than one external balanced (cutout) plate for the 904 and the 727's to deal with that? (2 each)
Re: 73 external balanced 340 [Re: dartphil] #2258047
02/23/17 01:54 AM
02/23/17 01:54 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://www.summitracing.com/parts/bmm-10235/overview/make/dodge
they only show that if fits a 727....but
this is the 73 340 externally balanced flexplate that needed to be used with NON Weight converter...
The damper needs to for an Externally Balanced 73 340 crankshaft also..if you do not have the original one ..Professional Products Makes a multi use balancer that has the correct weight that bolts on to the damper to work on a 340 cast crank..
the externally cut out 360 balancer does not interchange with the externally balanced 340...on either end of the engine. balancer or damper.
Tony
70 AARCuda Vitamin C
