Re: 500 inch 6 bbl engine
[Re: macmic87]
#2252536
02/12/17 08:43 PM
02/12/17 08:43 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Happy testing!!!
Looking forward to hearing the results.
I hope you find the time to test the ex manifolds....... I'm curious as to how much the power drops.
The last time I can recall doing that was on a stroker Cleveland Ford. Manifold friendly cam....... Did all the tuning with the manifolds on, since that's how it was going in the car. Still picked up like 40hp with the headers.
[Re: fast68plymouth]
#2254456
02/16/17 08:24 AM
02/16/17 08:24 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
stuska dyno... cant get it to re-set .. computer is not working properly.. got to get that fixed now.... did put some heat in it though... cant get the video to load...out board springs are to light .. changing to blacks next....
[Re: ek3]
#2254461
02/16/17 09:41 AM
02/16/17 09:41 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
stuska dyno... cant get it to re-set .. computer is not working properly.. got to get that fixed now.... did put some heat in it though... cant get the video to load...out board springs are to light .. changing to blacks next.... Did you get good data? If not, I would suggest that you not change anything on the set up until you do. Especially if there is only a bog as the operator is loading the dyno before the pull starts.
[Re: macmic87]
#2254548
02/16/17 01:32 PM
02/16/17 01:32 PM
fast68plymouth
So. Burlington, Vt.
Whenever I've dynoed a 6bbl motor, when the secondaries open it's usually rather abrupt........ Even when they're working fine in the car.
#2254640
02/16/17 04:18 PM
02/16/17 04:18 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2254675
02/16/17 06:00 PM
02/16/17 06:00 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
"Bog of the century". I tried that back in the 80's and my car fell flat on it's face instantly
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#2254835
02/17/17 12:12 AM
02/17/17 12:12 AM
BSB67
Prospect, PA
Whenever I've dynoed a 6bbl motor, when the secondaries open it's usually rather abrupt........ Even when they're working fine in the car. Sure. If you put lighter springs in and you load the engine the outboards will fully open before the pull is initiated. In this scenario, all 6 bbls are fully open and flowing on the main and you get good clean data right from the start of the pull. But if you instead have the carbs swing from fully closed to full open in a few hundred rpm right at the start of the pull it likely won't be representative of anything meaningful. I'm not suggesting that this is the only way, or necessary the right way, but is a good starting point for your testing and data collection.
[Re: macmic87]
#2255232
02/17/17 11:18 PM
02/17/17 11:18 PM
fast68plymouth
So. Burlington, Vt.
Russ, I'm sure I usually start the pulls at a higher rpm than what you would prefer. But as a result of the higher start rpm, the motor gets to see some rpm before the load starts being applied. When the throttle gets opened far enough to create some signal for the secondaries, they just pop open. This usually happens before you even get to wot, so on all the 6bbl testing I've done, the secondaries have always been wide open before the pull even starts.
[Re: BSB67]
#2255276
02/18/17 12:29 AM
02/18/17 12:29 AM
Cab_Burge
My first pull on my low deck 511 C.I. stroker pump gas six pak motor I had the dyno operator start at either 2000 or 2500 RPM (CRS) to 5000 RPM. I have since learned that on almost all the engine dynos used today if you set the start RPM on the keyboard and then slowly advance the throttle to full open all of them are at WOT before you can hit any button on the key board to start the automated pulls BTW, it took that first dyno operator several pulls to not bring the throttle back when the outboards carbs. would open and bog
[Re: macmic87]
#2255286
02/18/17 12:50 AM
02/18/17 12:50 AM
fast68plymouth
So. Burlington, Vt.
I know it's coming, so there is sort of an automatic pause with my hand in the application of the throttle. Bring the rpm up a bit, start feeding the throttle, pause briefly when the secondaries pop open, then push it open to WOT...... Let the rpm stabilize...... Start the pull.
[Re: macmic87]
#2255291
02/18/17 12:56 AM
02/18/17 12:56 AM
Posts: 4,689 Wichita
GY3
Wichita
Does the plan involve porting the Stealths?
A nice CNC job really wakes them up!
[Re: GY3]
#2256352
02/20/17 12:38 AM
02/20/17 12:38 AM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
A nice CNC job really wakes them up! no. running the stock exhaust manifolds i don't think it will help.
[Re: macmic87]
#2256397
02/20/17 02:14 AM
02/20/17 02:14 AM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
A nice CNC job really wakes them up! no. running the stock exhaust manifolds i don't think it will help. It would help with the right cam, just depends on what you want power wise & drivability .
[Re: macmic87]
#2256869
02/20/17 10:41 PM
02/20/17 10:41 PM
BSB67
Prospect, PA
A nice CNC job really wakes them up! no. running the stock exhaust manifolds i don't think it will help. What an interesting assumption.
[Re: BSB67]
#2257035
02/21/17 07:49 AM
02/21/17 07:49 AM
macmic87
lancaster, new york
A nice CNC job really wakes them up! no. running the stock exhaust manifolds i don't think it will help. What an interesting assumption. i don't want to assume anything so please any insight, advice, or recommendations i will take. thanks. just trying to get a stock appearing crisp running engine is the goal.
