440 truck swap? #2254439
02/16/17 03:52 AM
02/16/17 03:52 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
79 4wd ramcharger,orig 360 column shift tilt auto truck.What all shift linkage,if any is different from a small block to a big block? Just the cross shaft? Or frame side and tranny side brackets?
Re: 440 truck swap? [Re: crowbait] #2254886
02/17/17 02:19 AM
02/17/17 02:19 AM
Alberta
440_Offroader Offline
Alberta
I'm not 100% sure, but I'm thinking all the shift linkage would be the same. I think the only difference between a small block vs big block transmission, would be the housing bolt pattern to the block.
Re: 440 truck swap? [Re: crowbait] #2254905
02/17/17 04:21 AM
02/17/17 04:21 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I just did a 360 to 440 in the 77 W150 and all the shift linkage worked .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 440 truck swap? [Re: crowbait] #2254990
02/17/17 01:08 PM
02/17/17 01:08 PM
scratchnfotraction Offline
kickdown linkage is what you will have to find.
I used a 78 truck 3 piece on my 88-440 truck.
you will need
BB rear sump oil pan/oil tube and stick
(tube goes into pan)
(you will need to plug the hole in block for car oil dip tube if engine is sourced from a car.)
you will need a set of 4x4 BB motor mounts (4x4 are offset/driver side has clearance hole for oil pump bolt)
I would upgrade to a 7 blade fan on a HD max cooling thermo clutch/max cooling 4 core rad from a 78 3/4 ton BB truck.
rad is taller with 4 tubes and has a big metal fan shroud for 3/4 trucks
you may want to swap from the pancake booster to the smaller vac booster from a 78 BB truck for VC R&R clearance.
or use a 86 3/4 ton small booster along with the 86 pedal for hook up.
