Re: Has anyone made their own 1971 Dodge Charger Rubber bumpers?
[Re: migsBIG]
#2254341
02/15/17 11:03 PM
02/15/17 11:03 PM
Posts: 16,216 Mesa, Arizona
dart4forte
Mesa, Arizona
My buddy who owns a resto shop up in the NW does them. He'll probably need your core.
Abe Lincoln
[Re: migsBIG]
#2254853
02/17/17 12:08 AM
02/17/17 12:08 AM
dart4forte
Mesa, Arizona
To be honest, I would like to do it myself as shipping twice and then have them done would probably be very exspensive. I appreciate the help on it, but my budget leaves me doing most of the work myself. If I knew of the best sprayable rubber for my application was, I'm sure I could do it. He spent years experimenting until he got the process down. He's actually doing five bumpers for a guy up in Canada as we converse. I could probably transport your bumpers up there this August. I can ask him if he has some good cores if you like.
Abe Lincoln
[Re: migsBIG]
#2254903
02/17/17 02:48 AM
02/17/17 02:48 AM
Posts: 12,528 Western Colorado High Desert
moparmarks
I did a set though not 71 or Charger. Did it to a 72 RR/GTX. The B's are not like the E's that got a thick rubber coating. I used a high build primer with a flex agent. The B's have painted carriage bolts where the E's have welded studs. I welded and ground off the carriage bolts to be smooth like the E's. Lucky you doing a Charger and don't have to dish out 1800.00 for the Plymouth brow cap.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: migsBIG]
#2255111
02/17/17 05:01 PM
02/17/17 05:01 PM
Posts: 18,167 Mass
DAYCLONA
Mass
Thanks for the link flypaper, will check that out.
Rs23g I think I would need to what type and where to spray it on. I remember ( Dayclona I believe it might have been) gave a simple yet detailed description on how to do it, only problem was the recommended source nolonger exsisted or was absorbed by another company. If I can find something that is weather resistant to cold, heat and UV perfection, that would be even better. I mentioned in the past you have 2 direction you can take in making body colored bumpers for the 71 B bodies, either paint the bumpers after running a DA sander over the surface and edges to "soften" the look of the bumper, or sandblast them just enough to break the chrome layer (which is clear) and leave the nickel base, but still "soften" the edges/contours with a flap disc and DA sander, BC/CC gives the bumpers a thickened appearance Or if your adamant on having rubber coated bumpers, again sandblast/flap disk/DA the surface and edges to "soften" the surface of the bumper, then coat both sides with sprayable rubber coating from a SPRAY GUN, no spray can crap, you want a thin final coat on the backside to bond with the coats on the front/face, you'll need to spray perhaps a coat once a day, or every other day to get the build up as you need it, too many coats at once or too quickly will result in the rubber splitting because the thinner needs to gas out, and the rubber needs to shrink...depending on your spray application 3 coats on the fascia of the bumper will suffice, with the last coat being on the backside and fascia simultaneously to bond the whole mess together The factory bumper bolts were also rubber coated on just the surface of the heads, they also used a lower profile bumper bolt so the added rubber coating didn't appear too high, usually the replacement Ford bumper bolts for 60's early 70's vehicles have a nice low head profile... I buy the rubber from McMasterCarr pn# 9560T45 it's avalible in 1 gal, black, blue, red. or yellow...you want to be correct use black, after you've let the bumpers cure for a few weeks (the longer the better) paint as you would any flexible body part, using the correct primers/base/CC's along with the proper flex agents based on your paint choice/mfg With being in California you might have a problem "importing" the rubber and thinner required to spray because of your VOC compliance laws/rules, last I recall the thinner needed was Naphtha, but follow whatever the Mfg recommends for spraying, I know the formula of this rubber has changed over the years due to VOC compliance laws (it's actually thinner than originally formulated) What headlight set up are you planning on using? hope this helps Mike
[Re: DAYCLONA]
#2438371
01/21/18 12:19 PM
01/21/18 12:19 PM
Posts: 1,023 pa.
dan9
pa.
U-pol makes a spray urethane bed liner that is tintable to car color. I know the end product is textured . Does the texture come from the special spray gun? I wonder what it would look like if sprayed with a regular paint gun.
