Re: 426 engine VIN [Re: 6bblgt] #2254187
02/15/17 07:42 PM
02/15/17 07:42 PM
Lewiston, ID.
screemindemon Offline
Lewiston, ID.
PM me, please.
Re: 426 engine VIN [Re: screemindemon] #2254717
02/16/17 07:50 PM
02/16/17 07:50 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Originally Posted By screemindemon
I don't have a picture of the May SPD car, have to put it up on the lift. Font looks correct. But I have other full VIN engines/transmissions in the same Serial # range. I understand that they are not necessarily an indication of build date, but it appears they used full VINs up until the 275,XXX range? I'll check my other engines that I can get to and post some pics.
The hemi motor in my 68 RR came from a 69 RR. No idea of the car's SPD the translated date on the bottom rail is 9 Sept 68. The block was cast on 6-10-68. The side pad is stamped with a partial vin - "9A254886"
I posted this number some time ago in the lost and found section but nothing so far.
I had to do a double take on the earlier picture posted with the 68 stamping. That one was "8A287500" mine would be "580" I really had to look close and blow the picture up to see if the 0 might have possible been a 8...but it sure looks like a 0...
Still looking...
Re: 426 engine VIN [Re: 6bblgt] #2255395
02/18/17 08:03 AM
02/18/17 08:03 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Originally Posted By 6bblgt
the May '69 RR shouldn't have its full VIN stamped on engine/trans
the FULL VIN stampings are from the beginning of the model year until some time in January 1969 (all Charger 500s = FULL VIN & all Charger Daytonas = partial VIN)
got pics? scope
My March 69 built charger has full VIN on it.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: 426 engine VIN [Re: mopglen] #2255415
02/18/17 11:12 AM
02/18/17 11:12 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
My January 27th runner has a full VIN stamping. Getting pretty close to the end of the month.
1969 Hemi Roadrunner 2nd owner
Re: 426 engine VIN [Re: mopglen] #2255692
02/18/17 10:56 PM
02/18/17 10:56 PM
Lewiston, ID.
Lewiston, ID.
I stand corrected guys, I must have been confusing the May built Road Runner's engine with one of the other 69s I have. It does not have the full VIN stamped on the engine or transmission, just the last 8. Sorry for the confusion, too many cars and projects rolling around in my head!
Re: 426 engine VIN [Re: mopglen] #2864131
12/23/20 11:19 PM
12/23/20 11:19 PM
Canada
jerry9 Offline
jerry9  Offline
Canada
what does 426 HT stand for on an old 60's 426 wedge stand for ?
thanks
Re: 426 engine VIN [Re: jerry9] #2864159
12/24/20 12:21 AM
12/24/20 12:21 AM
Kirkland, Washington
Pacnorthcuda Offline
thanks
You sure about that? Normally I’d say H=1972 and T=Trenton plant...but 426?
Re: 426 engine VIN [Re: Pacnorthcuda] #2864216
12/24/20 09:26 AM
12/24/20 09:26 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Take a look here and see what block casting number you have.
Engine ID
Re: 426 engine VIN [Re: Pacnorthcuda] #2864469
12/24/20 07:20 PM
12/24/20 07:20 PM
Canada
jerry9 Offline
jerry9  Offline
Canada
yes i'm sure side of the block and all that is there is 426 HT NOT SURE WHERE the block came from it was bought by someone off the internet ot is strange as it has a gear drive and the cam spins backwatds it is on nickd garage , strnge beast for sure
Re: 426 engine VIN [Re: jerry9] #2864500
12/24/20 09:29 PM
12/24/20 09:29 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Industrial/marine engine?
Re: 426 engine VIN [Re: jerry9] #2864583
12/25/20 10:36 AM
12/25/20 10:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
So you don't have this engine, it's on another website? Which one. The most common Mopar site I'm aware of is this one Nick's Garage and I couldn't find it anywhere on that site.
Re: 426 engine VIN [Re: 6PakBee] #2864698
12/25/20 05:35 PM
12/25/20 05:35 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I have a friend with dual SB GMs in his boat and I believe one runs opposite to the other. So did Chrysler do the same when it came to running two Hemis in a boat. I know the Blown 426 I have from the boat runs like the way as a Car motor runs.
1971 HEMI E BODY REGISTRY
Re: 426 engine VIN [Re: hemicar1971] #2864721
12/25/20 06:27 PM
12/25/20 06:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: 426 engine VIN [Re: NITROUSN] #2867037
12/31/20 03:30 PM
12/31/20 03:30 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Not all gear drive RB engines were reverse rotation, I had a 413 from a truck that was gear drive, I still have the cam and gears.
