Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2255536
02/18/17 04:29 PM
02/18/17 04:29 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I want to change my steering column to something lighter.I just need to have directionals for street driving.UNlike FMJ,I don't need it to look stock. SO fellow members of this Jenny Craig club,what should I use??
[Re: fullmetaljacket]
#2255717
02/18/17 11:26 PM
02/18/17 11:26 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
RMCHGR, How'd you get those spy pictures? Are you a co-conspirator? I saved them from an old thread. Was looking through the contents of an old external hard drive the other day and I found them, thought they would be cool to post here. Again, I did get a few ideas from him though I don't go to quite the same extreme.
'71 Duster '72 Challenger '17 Ram 1500
[Re: hemi-itis]
#2255724
02/18/17 11:35 PM
02/18/17 11:35 PM
RMCHRGR
Spahn Ranch
I want to change my steering column to something lighter.I just need to have directionals for street driving.UNlike FMJ,I don't need it to look stock. SO fellow members of this Jenny Craig club,what should I use?? Al, check out Flaming River. They make generic 'motorsports' columns that weigh like 8 lbs. Paint it black, no one would know the difference. Flaming RIver column.
[Re: RMCHRGR]
#2255756
02/19/17 12:13 AM
02/19/17 12:13 AM
Posts: 4,695 Wichita
GY3
Wichita
Rumor has it a pair of Jenny Craig inspired original A990 fenders will go on sale at the Indy swap meet...
[Re: Thumperdart]
#2255849
02/19/17 02:38 AM
02/19/17 02:38 AM
hemi-itis
I figured out how to eliminate the weight of fender Chippin away,,,,,,,
[Re: Thumperdart]
#2255878
02/19/17 04:23 AM
02/19/17 04:23 AM
hemi-itis
I'm a leaner,,,,what's this????
#2255885
02/19/17 06:07 AM
02/19/17 06:07 AM
GY3
Wichita
Indy swap out in Indy or is it the Chicago swap? A990's are always a catch being that they are rare a probably more so than the 64' aluminum fenders. Aluminum can stick around for decades, where as steel, especially thin gauge steel can rust away easily if not stored away properly. Definitely Indy. March 3,4,5.
#2255929
02/19/17 12:14 PM
02/19/17 12:14 PM
GY3
Wichita
If I had the time, it would be cool to at least see those fenders up close. I traveled clear across the country just to retrieve a pair. The trick question would be if they are clean and not dented. Most are in rough shape. Very nice shape from what I was told.
[Re: GY3]
#2257334
02/21/17 07:43 PM
02/21/17 07:43 PM
Posts: 1,463 Martinsville, IN
cdwmotorsports
Martinsville, IN
Indy swap out in Indy or is it the Chicago swap? A990's are always a catch being that they are rare a probably more so than the 64' aluminum fenders. Aluminum can stick around for decades, where as steel, especially thin gauge steel can rust away easily if not stored away properly. Definitely Indy. March 3,4,5. 22nd Annual Chrysler Performance Show March 4-5, 2017 Indiana State Fairgrounds
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2258412
02/23/17 11:48 PM
02/23/17 11:48 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
So I've decided to take a few parts for Dad's 72 Duster under the knife. I have copied a few photo's from here and abroad to help me lighten the K frame. Kind of dual intent actually so if I ever have a problem I want to be able to pull the oil pan... I kind of screwed up out of the gate not weighing the old K frame but it really doesn't matter... I'm using a V8 74-6 style K frame and not the earlier one simply to keep everything the same as what was used on the 69 Dart. Never know when I may want to pull the 340 and slide a 416 in the Dart in a hurry... I plan on sourcing alum tie rod sleeves and possibly strut bars...I already have a Wilwood 4 1/2" brake conversion for the 10" drum spindles... Should be able to knock a fair amount of weight off... He ate two cutoff wheels and 2 sawzall blades last night...need to cut up a little flat stock and start fabbing up a few panels. Then I'm going to bolt it back in the car and mock everything up before final welding... Here's some before pictures of the victim...he's a little hinky and not the prettiest piece to start with but oh well... (maybe he's like a big girl? Knock a little weight off and have something I can work with)
...FAFO...
