1968 charger emblem placement over 1/4 panel #2252379
02/12/17 03:57 PM
02/12/17 03:57 PM
old westchester
mcat4321 Offline OP
mcat4321  Offline OP
old westchester
i am reassembling a car i did not take apart, the 1/4s have been replaced, and not drilled, i need to know where the charger script emblems over the 1/4 panel goes. (outer sail panel?) a very close approximate.
thanks guys
Re: 1968 charger emblem placement over 1/4 panel [Re: mcat4321] #2253503
02/14/17 12:28 PM
02/14/17 12:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
bump
Re: 1968 charger emblem placement over 1/4 panel [Re: mcat4321] #2253994
02/15/17 12:15 PM
02/15/17 12:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Can't beleive no one has replied, down If you still need the info I will got to my storage facility and snap a couple of pic's. let me know beer
Re: 1968 charger emblem placement over 1/4 panel [Re: mcat4321] #2254290
02/15/17 10:02 PM
02/15/17 10:02 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I think no one has replied because this location is not easy to precisely describe....I've looked at my Charger and there are no precise points to measure from.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 1968 charger emblem placement over 1/4 panel [Re: mcat4321] #2254307
02/15/17 10:28 PM
02/15/17 10:28 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
ask you ? here
LINK FOR YOUR QUESTION
Re: 1968 charger emblem placement over 1/4 panel [Re: mcat4321] #2254994
02/17/17 12:22 PM
02/17/17 12:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks guys
here's the best I can do for you based on what I have for dimensions, if your car has the vinyl roof moldings the "imaginary" line I drew under the emblem's bottom baseline of the script runs parallel with the moldings, keep in mind both sides of a car rarely match in shape/dimensions, my dimensions were taken from factory locations of the emblems
Mike
Re: 1968 charger emblem placement over 1/4 panel [Re: DAYCLONA] #2255007
02/17/17 12:47 PM
02/17/17 12:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks guys
Mike
bow
