Re: 440 Iron head build only
[Re: Cab_Burge]
#2247482
02/05/17 12:16 AM
02/05/17 12:16 AM
Posts: 4,804 Wichita
GY3
Wichita
Acid porting is usually used to cover up grinding and real porting work done with carbide bits It makes the cast iron look like porous cast iron again Cheating
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: JohnnyBeGood]
#2251131
02/10/17 05:08 PM
02/10/17 05:08 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have four sets of iron heads being done here at the shop right now, and another set on the way. Iron still lives on!! 3 sets need to be iron for what the owners are doing with the cars, another set doesn't "have to" be, but really "should" be....... The last set, they wouldn't really need to be, and if it were my decision, I'd probably use stealth heads on it, but the car owner wants to use the original heads.
[Re: fast68plymouth]
#2251213
02/10/17 07:33 PM
02/10/17 07:33 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
I have four sets of iron heads being done here at the shop right now, and another set on the way. Iron still lives on!! 3 sets need to be iron for what the owners are doing with the cars, another set doesn't "have to" be, but really "should" be....... The last set, they wouldn't really need to be, and if it were my decision, I'd probably use stealth heads on it, but the car owner wants to use the original heads. not every application needs aluminum heads and/or stroker kits, but online people will gladly spend your money for you
[Re: JohnnyBeGood]
#2251267
02/10/17 09:26 PM
02/10/17 09:26 PM
fast68plymouth
So. Burlington, Vt.
Rarely is it less expensive to rework iron heads than buy aluminum, if there are "budget friendly" aluminum heads available for what you're building....... And that's the case for BB mopars for sure. Oh, and I had forgotten about one set....... So, 5 sets here, another set on the way
[Re: JohnnyBeGood]
#2251701
02/11/17 04:55 PM
02/11/17 04:55 PM
fast68plymouth
So. Burlington, Vt.
My advice to the original poster is to call the guy with 5 sets of iron heads in his shop. That reminded me....... There's actually 6 sets here...... and another on the way. Oh, and that's just the Mopar heads. I'm not sure if iron hemi heads count, but if so..... Then add another set. Got a few others of some different make iron stuff here as well..... And more on the way. I don't mind working on them at all. As long as the person having them done understands that quality work takes time...... And time is $$$$.
#2252120
02/12/17 10:03 AM
02/12/17 10:03 AM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
I'm one of the few guys that still thinks there is a place, albeit limited, for iron heads. If you are looking for max power without other personal choice restrictions, iron seems silly. But, if you are in the 500 hp or less bucket you simply don't need aluminum after market either. I am not an anti-Chinese guy, but if I can reach my goal with iron, and pay a local guy (my first choice) or a domestic guy $1600 to do work, that will be a serious consideration for me. In this power range, it is the weight savings that puts me on the fence.
[Re: JohnnyBeGood]
#2252264
02/12/17 02:21 PM
02/12/17 02:21 PM
fast68plymouth
So. Burlington, Vt.
The weight, and the cost/ease of getting good quench........since there are far more open chamber heads than closed for the iron lovers to use.
[Re: JohnRR]
#2603517
01/08/19 05:49 PM
01/08/19 05:49 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I have some crazy modified stock iron intakes too, one from fast68plymouth ... and one that was acid ported ...
You got pictures of that?
Moparlee
[Re: Robbins]
#2720145
11/28/19 07:40 PM
11/28/19 07:40 PM
Posts: 55 CT
roadrunner2
CT
Two years later, John, and I’d like to see those pictures now.
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’ Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST. 10:1 451” replaced with 14:1 499”.
[Re: roadrunner2]
#2720235
11/29/19 12:11 PM
11/29/19 12:11 PM
fast68plymouth
So. Burlington, Vt.
Not work I did, but here’s a couple of pics of a low deck intake that is being used in FAST & Super Car.
#2720258
11/29/19 02:45 PM
11/29/19 02:45 PM
Robbins
Joplin, MO USA
Not work I did, but here’s a couple of pics of a low deck intake that is being used in FAST & Super Car. I thought I read where folks tried this mod amd hurt it. Cool if it works.
Moparlee
[Re: Robbins]
#2720626
12/01/19 01:17 PM
12/01/19 01:17 PM
fast68plymouth
So. Burlington, Vt.
I can tell you that the intake in the pics ended up that way thru testing in the car at the track.
