1970 Duster Master Cylinder Cover Style? Bolt or Lever? #2251370
02/10/17 11:37 PM
02/10/17 11:37 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What is the correct style cover for a manual brake master cylinder on a 1970 Duster? Lever or Bolt in Center?
Re: 1970 Duster Master Cylinder Cover Style? Bolt or Lever? [Re: vinnyd76] #2251378
02/10/17 11:57 PM
02/10/17 11:57 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The one on the left is for drum brakes although not correct appearance wise. the one on the right is for disc/ drum applications.
Re: 1970 Duster Master Cylinder Cover Style? Bolt or Lever? [Re: formula_s] #2251387
02/11/17 12:09 AM
02/11/17 12:09 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Correct style is the one on the right with the wire hold down as mentioned.
For the gotta be original crowd the oem part number for the 1970 a-body disc brake master cylinder is 2229171 (I think). Those are hard to get, and the prices can be absurdly high.
Re: 1970 Duster Master Cylinder Cover Style? Bolt or Lever? [Re: vinnyd76] #2251457
02/11/17 02:40 AM
02/11/17 02:40 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
I bought a 70 Duster around 76 with 25,000 miles, /6 auto with standard disc and had the one similar to the one on the left, easy to tell it had never been off. Could have been a mistake from factory. Made into a race car and was the best stoping car I ever owned. Original has a strap over the top where he bolt goes thru. Every power disc brake one I have seen has the one on the right.
Re: 1970 Duster Master Cylinder Cover Style? Bolt or Lever? [Re: vinnyd76] #2252621
02/12/17 09:49 PM
02/12/17 09:49 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
My manual 4-wheel drum '70 Duster (/6) uses a bolt on cover. It's been in our family since '78 or so.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1970 Duster Master Cylinder Cover Style? Bolt or Lever? [Re: DynoDave] #2252874
02/13/17 10:57 AM
02/13/17 10:57 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Drum is bolt on. One shown in OP's picture is an aftermarket, the one in this ebay listing is original
Drum master cylinder
Disc used a bale wire hold down. Original casting number was 2225541
