Dakota interchange verification question #2251330
02/10/17 11:16 PM
02/10/17 11:16 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
this is my 6th square body Dakota, but 1st that I am doing bodywork on. What is door interchange on 87-96s? This one's a 96, but strangely the cleanest doors in the local yard came from an 87. Especially strange for northern Illinois.
Outside door handles are missing, can I just swap them from the 96? pass. door latch also MIA, due to previous junkyard customer.
Any difference between reg cab and club cab?
need to know for certain before I spend the time and $$$ to have them scuffed and sprayed.
also on the 90s ones, they all had fender flares and black body side molding. that 87 was cleaner looking without (and less place for water to collect and start rust) are these glued, screwed or clipped on, like the 60s and 70s metal side molding was?
Re: Dakota interchange verification question [Re: volaredon] #2252786
02/13/17 03:02 AM
02/13/17 03:02 AM
ILLINOIS
V
V
ILLINOIS
bump cmon nobody?
Re: Dakota interchange verification question [Re: volaredon] #2252803
02/13/17 03:42 AM
02/13/17 03:42 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I believe they would be the same i would check the door latch location to be sure they look identical the flares are screwed onto the fender lips . I have had 5 square bodys and a lot of the parts will interchange .
Re: Dakota interchange verification question [Re: mopwrd340] #2252877
02/13/17 12:08 PM
02/13/17 12:08 PM
ILLINOIS
V
V
ILLINOIS
ok, I know about the flares attachment at the wheel wells, but I was more asking about attachment to the flat sections of the body..... I'd like to remove it all (permanently)
thanks for the response.
Re: Dakota interchange verification question [Re: volaredon] #2253303
02/14/17 01:01 AM
02/14/17 01:01 AM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
That black rubber body side molding is glued/taped on. A couple pieces of mine were about to fall off, so I had to reattach them.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
