Re: Harland sharp or T+D rockers for 440-1 heads...
[Re: MoParFish]
#2250378
02/09/17 04:01 PM
02/09/17 04:01 PM
Posts: 43,375 Bend,OR USA
Cab_Burge
It seems there are several different choices when it comes to moving or rotating parts, bushings, ball bearings, tapered bearings, needle bearings and caged needle bearings, pick your poison
[Re: voigtspeed]
#2250442
02/09/17 04:53 PM
02/09/17 04:53 PM
Posts: 4,457 Washington
madscientist
Washington
Jesel makes their endurance rockers from steel with bushings.
What else can I say?
[Re: madscientist]
#2250444
02/09/17 04:56 PM
02/09/17 04:56 PM
Posts: 20,207 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What else can I say? Do you have them on your race car and if so for what head. How was the geometry
[Re: Monte_Smith]
#2250447
02/09/17 04:59 PM
02/09/17 04:59 PM
madscientist
Washington
If anyone is interested in the real engineering design guidelines for needle bearings you can find it here: http://www.ntnamericas.com/en/website/do...13-e_lowres.pdfWhat you'll find is that needle bearings work just fine for oscillating shafts as long as the angle of oscillation is greater than the distance between the bearings. If you look at a Jesel rocker arm you'll see that they are properly engineered. Some of the super cheap Chinese crap rocker arms use large diameter needle bearings and if you use them with low lift cams you might have a lubrication problem. There shouldn't be a problem with any of the high quality vendors such as T&D or Jesel. Most high end equipment uses needle bearings in oscillating configurations. I used to work plant maintenance at a Monsanto plant on very complex and precision fiber tow and drawtwist machinery. Bushed parts can't be machined to close enough tolerances to maintain alignment. While that may not truly matter on something like a rocker arm, it damn sure can't hurt. Bottom line..........it's BETTER Im not sure you can't machine a bushing to close enough tolerance, the question is, is it profitable. There are things such as down time etc and also making parts to repair a machine that will is 50 years old. Needle bearings have a place. Typical of the Internet world, some people have to fabricate [censored] and make up [censored] I didn't say. The man who taught me to never use needle bearings on a reciprocating shaft wan an engineer who designed machines for industry. Not one that I know of ever went out with needle bearings. To compare a rocker arm with a ujoint is silly. There is more to it that how far the rocker rotates. But I'll leave it here. Do what you want. But 99.999% of the [censored] you buy is compromised because it's easier to do something then to do it right. It's about money.
[Re: pittsburghracer]
#2250455
02/09/17 05:04 PM
02/09/17 05:04 PM
madscientist
Washington
What else can I say? Do you have them on your race car and if so for what head. How was the geometry What difference does it make if I have them? If they stopped making aluminum bodied rockers and did them all in steel, the price would come down to where they would be more affordable. Simple isn't it? The other issue is, especially with cheap ass mopar guys who still think a stock block is a great deal won't buy any rocker over the cost of a set of HS, my least favorite rocker there is. Broke enough of them to know it's nearly impossible to get the geometry close for 8800 RPM without issues. You can make it for a Chrysler but the cheap asses won't buy it. Guys still [censored] about W-2 rocker costs. My current engine runs Norris stainless steel rockers. No needle bearings. Rocker geometry is pussy good.
[Re: voigtspeed]
#2250459
02/09/17 05:12 PM
02/09/17 05:12 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
FWIW my old B1MC deal had T&D rockers on it and still does. They have seen over 1000 passes at this point with right at 1100lbs of open pressure and never seen a failure. Oh yeah they have needle bearings too
[Re: DoubleD]
#2250520
02/09/17 06:33 PM
02/09/17 06:33 PM
madscientist
Washington
The late winter peeing contest is in full force - must mean the racing season is just around the corner!
Just for what it is worth I am an Engineer and I run needle bearings! Well them it must be right. Again, why does Jesel make their endurance rockers out of steel? With bushings? We all know that dirt bikes went to needle bearing because of cost. That was in print many times. Just like Honda using aluminum frames. They did it because aluminum was cheaper and more available than steel. They marketing guys had to sell it and they did. It's the same thing with rockers. It's all marketing. And, if your getting 1K plus passes from a set of rockers, are you give up performance? Would you expect aluminum rods to have that many life cycles? If the did, they'd be so big as to be worthless. I'd bet there isn't a top ten PS car with needle bearings. Probably not many with aluminum rockers either.
[Re: madscientist]
#2250581
02/09/17 08:06 PM
02/09/17 08:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just for what it is worth I am an Engineer and I run needle bearings! Well them it must be right. Again, why does Jesel make their endurance rockers out of steel? With bushings? We all know that dirt bikes went to needle bearing because of cost. That was in print many times. Just like Honda using aluminum frames. They did it because aluminum was cheaper and more available than steel. They marketing guys had to sell it and they did. It's the same thing with rockers. It's all marketing. And, if your getting 1K plus passes from a set of rockers, are you give up performance? Would you expect aluminum rods to have that many life cycles? If the did, they'd be so big as to be worthless. I'd bet there isn't a top ten PS car with needle bearings. Probably not many with aluminum rockers either. On your last statement here you would be wrong
[Re: madscientist]
#2250587
02/09/17 08:11 PM
02/09/17 08:11 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Originally Posted By DoubleD The late winter peeing contest is in full force - must mean the racing season is just around the corner! Just for what it is worth I am an Engineer and I run needle bearings! Well them it must be right. Again, why does Jesel make their endurance rockers out of steel? With bushings? Maybe because they did not want to jump in the same market as everyone else and to make their product unique? Maybe it's not the best but it is different so they will get a different following. Does not PROVE that their design is better but different. Move on - next subject please this one is getting boring.
[Re: BradH]
#2250619
02/09/17 08:52 PM
02/09/17 08:52 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I seriously think somebody needs a Snickers Bar That is clearly not a Snickers bar!!
[Re: MR_P_BODY]
#2250661
02/09/17 09:46 PM
02/09/17 09:46 PM
madscientist
Washington
Just for what it is worth I am an Engineer and I run needle bearings! Well them it must be right. Again, why does Jesel make their endurance rockers out of steel? With bushings? We all know that dirt bikes went to needle bearing because of cost. That was in print many times. Just like Honda using aluminum frames. They did it because aluminum was cheaper and more available than steel. They marketing guys had to sell it and they did. It's the same thing with rockers. It's all marketing. And, if your getting 1K plus passes from a set of rockers, are you give up performance? Would you expect aluminum rods to have that many life cycles? If the did, they'd be so big as to be worthless. I'd bet there isn't a top ten PS car with needle bearings. Probably not many with aluminum rockers either. On your last statement here you would be wrong So you know this for fact? That the top PS guys are using aluminum rockers? I know what a nascar guy says on speed talk about what they run.
[Re: madscientist]
#2250664
02/09/17 09:53 PM
02/09/17 09:53 PM
MR_P_BODY
Just for what it is worth I am an Engineer and I run needle bearings! Well them it must be right. Again, why does Jesel make their endurance rockers out of steel? With bushings? We all know that dirt bikes went to needle bearing because of cost. That was in print many times. Just like Honda using aluminum frames. They did it because aluminum was cheaper and more available than steel. They marketing guys had to sell it and they did. It's the same thing with rockers. It's all marketing. And, if your getting 1K plus passes from a set of rockers, are you give up performance? Would you expect aluminum rods to have that many life cycles? If the did, they'd be so big as to be worthless. I'd bet there isn't a top ten PS car with needle bearings. Probably not many with aluminum rockers either. On your last statement here you would be wrong So you know this for fact? That the top PS guys are using aluminum rockers? I know what a nascar guy says on speed talk about what they run. Would seeing them be good enough for you.. yes I seen them when I was in the pits being in AJs pit in Norwalk... and I actually picked one up after asking if I could
[Re: MoParFish]
#2250943
02/10/17 11:13 AM
02/10/17 11:13 AM
Posts: 19,708 north of coder
moparx
Show me where it is acceptable to use a needle bearing on a reciprocating shaft other than a rocker arm There have been billions of them in service, run for trillions of miles for trillions of hours, for over a century....... It's called a universal joint. Was thinking the same thing... as was i, but the drive shaft has an angle built in, be it pinion angle [ ] or an offset to the left or right to promote the bearings to fully rotate around the shaft discouraging brinneling [sp ?] of the shaft. independent rears [think corvette] for a good last few years are back to a torque tube type of driveshaft because u joints are not needed for connection from engine to differential. good discussion, but you guys are confusing my old, confused mind more and more. keep this going, please.
#2250955
02/10/17 11:40 AM
02/10/17 11:40 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
What else can I say? Do you have them on your race car and if so for what head. How was the geometry I doubt he has them, feel free to post a pic if you do have them because the following taken directly from Jesel website for standard and optional features for their PRO STEEL SERIES SHAFT ROCKERS Heat Treated Alloy Steel Body-STANDARD Tool Steel Cup Adjuster-STANDARD Tool Steel Ball Adjuster-OPTIONAL Adjusterless Bronze Pushrod Seat-OPTIONAL ARP 12pt Adjuster Nut-STANDARD Needle Shaft Bearings-STANDARDCenterless Ground .561” Shaft-STANDARD .250” Wide Needle Nose Roller-STANDARD MoHawk Beam-STANDARD Profiled Rocker Tail-STANDARD ARP Mounting Hardware-STANDARD Custom Stand Configurations-STANDARD Zero-Thrust Stand Assembly-STANDARD Zero-Thrust Box Style Stand-OPTIONAL
[Re: voigtspeed]
#2251090
02/10/17 04:10 PM
02/10/17 04:10 PM
Al_Alguire
Las Vegas
My 99 Hemi, IE PRo Stock Hemi had needle bearing. We were just on the dyno Wednesday at a Pro Stock shop and they have needle bearing rockers as well, so I guess I know this for a fact. This is a team that has won including in 2016. As with mine they were WW Rockers and all had needles, they seem to be the rocker many teams run from what I've seen anyway. These were engines from Johnson(hemi) and Elite(drce). I have seen some steel rockers on Dodge stuff to but usually only on one side and they had needle bearings as well. So I guess the statement about pro stock not using them is not quite 100% correct.
[Re: voigtspeed]
#2251122
02/10/17 04:56 PM
02/10/17 04:56 PM
madscientist
Washington
Well then keep doing what you are doing.
I was going to call a few people but why bother? You guys are doing it so it must be right.
[Re: voigtspeed]
#2251126
02/10/17 04:59 PM
02/10/17 04:59 PM
Al_Alguire
Las Vegas
All I've said is I have never had an issue with a GOOD rocker with a bearing. And that MY 99 Hemi as well as a few other I know of are using them as well. I juts know what I have seen and done.
