Page 5 of 5 1 2 3 4 5
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2251128
02/10/17 05:02 PM
02/10/17 05:02 PM
Washington
skrews Offline
skrews  Offline
Washington
Someone just needs to take their ball and go home.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: skrews] #2251209
02/10/17 07:30 PM
02/10/17 07:30 PM
Washington
madscientist Offline
Washington
Unlike some on here who just blow smoke and talk [censored], I'll do some research. I no longer have the paper that discussed why not to use needle bearings on a reciprocating shaft, but it was more than just getting the needles to roll.
I realize the majority is always right.
Since I have done some actual testing, I don't give a shot what most guys do. There was ZERO power when I tested it. It would be nice if someone else tested it
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2251230
02/10/17 08:15 PM
02/10/17 08:15 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Mad you are mad if you really believe manufacturers use bearings because are cheaper than bushings
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: The Shadow] #2251239
02/10/17 08:41 PM
02/10/17 08:41 PM
Washington
Washington
What do you think about lifters with bushings? Once they figured out a material and how to get it oiled, many people switched, even though many gurus thought it a bad idea?
I also said it was marketing.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2251314
02/10/17 10:43 PM
02/10/17 10:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
What did I miss??? I had to go change my diaper. Lol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2251345
02/10/17 11:41 PM
02/10/17 11:41 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Originally Posted By madscientist
Dirt bikes used to have bushings in the swing arm pivots. Then they figured it was cheaper to use a bearing and out went the bushing. The bearings never last very long.
Completely wrong and has nothing to do with cost. Just your speculation same as your view on needle bearing rockers
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: pittsburghracer] #2251348
02/10/17 11:43 PM
02/10/17 11:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
laugh argue with a guy who's handle is "Mad Scientist" I got to admit that's some quality trolling- unless he really believes his rants. Just got to his profile, click "ignore this user", and miss nothing. twocents
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2251468
02/11/17 05:59 AM
02/11/17 05:59 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Damn! Through all of this opinionated BS did the OP's question ever get answered? I'll say that I bought the T&D's for my -1 setup with a .690 lift cam and they have been flawless for three years on the division trail. Quality product and they PAY!
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2251469
02/11/17 06:25 AM
02/11/17 06:25 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
First set of roller rockers I ever saw were on a 331 SBC back in 1972. I asked the guy what the advantage was and his answer was so he could restrict the oil flow to a trickle to the top and keep more in the bottom where it was needed. That doesn't sound like a band-aid to me.
