Re: School me on Dry Sump set ups.
[Re: rebel]
#2250393
02/09/17 04:14 PM
02/09/17 04:14 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
I have not used a new style Peterson pump. IMO vacuum is a good thing and if you cannot get to 17-20 you need a vacuum pump..Just my .02
[Re: rebel]
#2254097
02/15/17 04:48 PM
02/15/17 04:48 PM
Al_Alguire
Las Vegas
My current Moroso only pulls 9" on its own so we run a vacuum pump as well. Will be replacing it with a Daily eventually. IMO 10" is not enough. We run a 4 vane and no regulator to pull 18"
[Re: Al_Alguire]
#2254118
02/15/17 05:34 PM
02/15/17 05:34 PM
Posts: 4,647 aotearoa
rebel
aotearoa
My current Moroso only pulls 9" on its own so we run a vacuum pump as well. Will be replacing it with a Daily eventually. IMO 10" is not enough. We run a 4 vane and no regulator to pull 18" thanks Al. I'm still wondering about the Missile pump. are they still around & are they any good?
[Re: rebel]
#2254125
02/15/17 05:42 PM
02/15/17 05:42 PM
Al_Alguire
Las Vegas
IMO not sure your reason for wanting to change but I don't think you will find any power there at all over a good wet sump system at all.
