Torque convertor manufacturer recomendations #224876
02/14/09 05:34 PM
02/14/09 05:34 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I'm looking for a torq conver to use in a mostly stock 1971 340 build. based on cam profiles and rear gear in the 3.55 range I was thinking something with a stall in the 2400-2700 rpm range
Also, anyone know who makes the convertors Mopar Perf sells ?
Re: Torque convertor manufacturer recomendations [Re: gtx6970] #224877
02/14/09 10:50 PM
02/14/09 10:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I cant help you Bill but I can say the Dynamic and Turbo Action convertoers I have used work great. I am sure if you call them they can make you a nice converter. Ron
Re: Torque convertor manufacturer recomendations [Re: gtx6970] #224878
02/14/09 10:57 PM
02/14/09 10:57 PM
Central NC
gch Offline
gch  Offline
Central NC
For what you are looking for an off the shelf 11" unit will likely work.Turbo action,ATI,coan,and smr trans out of Canada are the ones I will vouch for personally.
