Under car rearend Video #2248175
02/06/17 12:21 AM
02/06/17 12:21 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Under car rearend Video [Re: WHITEDART] #2248190
02/06/17 12:38 AM
02/06/17 12:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It looks smooth. Is that three lowering blocks stacked on each side?
Re: Under car rearend Video [Re: justinp61] #2248198
02/06/17 12:50 AM
02/06/17 12:50 AM
bean town ....Ca
W
W
bean town ....Ca
Yes
Re: Under car rearend Video [Re: WHITEDART] #2248226
02/06/17 01:35 AM
02/06/17 01:35 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Dang that tire looks big compared to my 26s lol. Cool video, I need to do one of those
Re: Under car rearend Video [Re: SpareParts] #2248229
02/06/17 01:40 AM
02/06/17 01:40 AM
bean town ....Ca
W
W
bean town ....Ca
28.10.5 track conditions were very poor that day... we had a tuff day but still managed to come home with a nice check...
Re: Under car rearend Video [Re: WHITEDART] #2248236
02/06/17 01:52 AM
02/06/17 01:52 AM
does it look like the tires start to unload a little bit about two to five inches out from the launch confused ?
Re: Under car rearend Video [Re: WHITEDART] #2248281
02/06/17 03:04 AM
02/06/17 03:04 AM
'murica
misfired Offline
misfired  Offline
'murica
Looks good, what was your tire pressure? Looks like time for radials to me....
Also any wheelie bars on your car?
Re: Under car rearend Video [Re: WHITEDART] #2248284
02/06/17 03:14 AM
02/06/17 03:14 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Cab has it right, this is far from smooth. Shocks are too soft on extension. If you freeze it at the hit, the sidewall is compressed to about half it's height. And the car is out a bit before it actually "stands" the tire up. All that is eating 60ft. It pounded the tire so hard, it was a whisker from blowing them off. Watch the video again. You nearly see daylight under left rear when it hammers, cups and rebounds.
Re: Under car rearend Video [Re: Monte_Smith] #2248340
02/06/17 10:49 AM
02/06/17 10:49 AM
PA
Harry's Taxi 2 Offline
PA
What would be the shock setting to shoot for....no sudden separation/extension with minimal to no tire compression or just a slower separation with more tire pressure to minimize tire squash?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Under car rearend Video [Re: misfired] #2248377
02/06/17 12:19 PM
02/06/17 12:19 PM
bean town ....Ca
W
W
bean town ....Ca
13.5 was the air pressure..and no bars on car...I had a set of 275s pro in the pit...but I would have never got them to work that day...
Re: Under car rearend Video [Re: Monte_Smith] #2248387
02/06/17 12:36 PM
02/06/17 12:36 PM
bean town ....Ca
W
W
bean town ....Ca
I agree 100% with the shock needing more extension control... and actually started off that way... wrong or right we actually were able to get the car to go down the track this way.. track prep was non-existent for this import vs. Domestic shootout... with our normal shock settings the car would not even moved 1 inch before blowing the tire off.. Im still new at this and learning every day... appreciate your guyses input..
Re: Under car rearend Video [Re: WHITEDART] #2248392
02/06/17 12:40 PM
02/06/17 12:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I need to pay more attention. I just watched the video again, this time starting and stopping, it took several times but Monte is right. In the seven second frames there is a little wisp of daylight in the center of the drivers slick. In the same frame the passengers side appears to be starting to fold up too.
Monte, What's the cause and what's the fix?
Re: Under car rearend Video [Re: WHITEDART] #2248436
02/06/17 01:34 PM
02/06/17 01:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Its just hammering the tire. It may simply need to be tighter on rear extension. But it may also need tighter front extension, an air pressure adjustment, weight bias change or all the above. All I know is what I see in that video and that is the tire is very unhappy. From previous discussions about the lack of 60ft from this car, I would say this is an ongoing issue.
If it will only work on a marginal track by punishing the tire as he alluded to above......the set up is off.
The thing about data and video, is that it is great to have, but you have to learn to use it. Guys also get caught up in a goal......lets say 60ft. BUT, don't worry about 60ft, until you go 30ft and don't worry about 30ft until you go 10ft. Fix the FIRST thing wrong. And in this case it's the way the car hits the tire. If you don't fix this, you will never fix anything else.
Re: Under car rearend Video [Re: WHITEDART] #2248445
02/06/17 01:47 PM
02/06/17 01:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice run and you know you cant stack spacers/shims like that.............just sayin.......... biggrin
Re: Under car rearend Video [Re: WHITEDART] #2248448
02/06/17 01:52 PM
02/06/17 01:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Well, that remains to be seen, because as discussed above, this car is far from working very good. It has issues, which is why I suspect he posted the video.
The stacked spacers puts the leverage point well away from the spring. Maybe the shock is good enough to control pinion rise with the added leverage, maybe it's not. That remains to be seen
Re: Under car rearend Video [Re: WHITEDART] #2248467
02/06/17 02:17 PM
02/06/17 02:17 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Can't or don't know how to do it with You Tube but if you have the original video, I found a free player called "media player home classic cinema" from https://mpc-hc.org/. You can slow a video down 10X. Works great for viewing launches.
Re: Under car rearend Video [Re: Monte_Smith] #2248473
02/06/17 02:25 PM
02/06/17 02:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Thanks.
Re: Under car rearend Video [Re: WHITEDART] #2248482
02/06/17 02:34 PM
02/06/17 02:34 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Always nice to learn from this type of info.
69 GTX 68 Road Runner
Re: Under car rearend Video [Re: Monte_Smith] #2248528
02/06/17 03:37 PM
02/06/17 03:37 PM
bean town ....Ca
W
W
bean town ....Ca
[quote=Monte_Smith]Well, that remains to be seen, because as discussed above, this car is far from working very good. It has issues, which is why I suspect he posted the video. ..................... I think everyone that watches the video can tell my car is a piece of sh!t.. I never claimed to be the best or better than than anyone else... I already explained that I didn't think the shock settings were correct. But that's where I ended up that day.. to go A to B....
Re: Under car rearend Video [Re: WHITEDART] #2248543
02/06/17 03:50 PM
02/06/17 03:50 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Nobody said anything about your car being that. But you have posted several questions here, as well as putting up this video. Only trying to help you, based on what I see. If you would rather not have any more comments from me........I will gladly bow out, just say the word.
Trying to make a small tire leaf car 60ft hard is a tough job. You are doing fine, but there is definitely more there. In case you haven't noticed, I don't sugar coat things......LOL!!! Ask me what I see or think and I will tell you. I would rather hear things straight and that's the way I tend to give it. Some are not like that and I understand that as well. We are grown men, should be able to have a conversation and not take it personally..........because it's NOT personal. You don't know me, I don't know you.
