Page 5 of 6 1 2 3 4 5 6
Re: Jensen Interceptor.... :p [Re: autoxcuda] #224824
02/20/10 12:41 AM
02/20/10 12:41 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
Thanks for the pics!
I figure I will swap out tips at a later date, I'm trying to get it on the road right now.
It's running, driving, stopping and steering, I have a real issue with lack of traction, but that's another story.....
Car runs strong, but I'm still working the bugs out....
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224825
02/20/10 01:40 AM
02/20/10 01:40 AM
Don't forget to come and take me for a ride.
Re: Jensen Interceptor.... :p [Re: ] #224826
02/20/10 02:19 AM
02/20/10 02:19 AM
Canada
Canada
It'll have to be on a fairly wide street until I get the traction problem sorted....
I have a few bugs left, I get my needed switches tomorrow I hope..... I had better be ready for spring I tell ya!
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224827
06/12/10 04:30 PM
06/12/10 04:30 PM
Canada
Canada
Well after a few months of house renos, I started putting away tools, which lead to opening up the garage, which lead to pushing my Coupe out which in turn required the Jensen being moved....
SoooOooo....
I just HAD to start working on the Jensen a wee bit... LOL
Got my front end nicely settled at ride height, so I have tightened up all my suspension and threw in some cotter pins. I noticed my toe-in was out by quite a bit, so I did an eyeball alignment which I hope is good enough to get me to the alignment shop.
Made pieces to fasten both the chokes open and installed them... and I changed my turn signal stalk to a proper Interceptor turn signal stalk. I have to get the wiring ends on but I tested it and it indeed works like I should!
I have to get my windows working (I removed my AC and will retrofit later) and then I think I am on the road!!!!!!
I have two new K&D switches, and access to quite a few window motors.... so I just have a bit of work to do on the windows, finish my stereo install, and then I am on the road for the summer!
I'll post pics of my breakdowns, videos of me pushing the car home, and the amount of tears I shed in future posts....
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224828
06/12/10 05:51 PM
06/12/10 05:51 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Haha!
Here's a thread on my Jensen, I bought it last year and have gotten it running. Drove it around the block too... it's been sitting since 1991, when the engine, transmission and radiator were redone. The owner never touched the car for 17 years....
The way I got it.....
Great car!! An Icon of cool performance and style!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224829
06/19/10 05:14 PM
06/19/10 05:14 PM
Canada
Canada
Dun-dun-DUH!!!!!!
Insured it today.... it actually drives pretty danged good so far. Only 20 minutes cruising so far, but drives straight, shifts nice, corners flat, it seems pretty good.
A little bit of DrOnE at ilde and cruising speeds though... but I have my driver's door panel off and both windows were down...
Gotta start sorting out the bugs and taking a few longer trips, but so far I am a HAPPPY camper!
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224830
06/19/10 06:28 PM
06/19/10 06:28 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Re: Jensen Interceptor.... :p [Re: FuryUs] #224831
06/19/10 10:32 PM
06/19/10 10:32 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: Jensen Interceptor.... :p [Re: RodStRace] #224832
06/20/10 12:06 AM
06/20/10 12:06 AM
Canada
Canada
Runs pretty good, drives really nice, a few bugs to work out and then I'll try a bit of power down to the ground...
http://www.youtube.com/watch?v=NStpPLbRPL4
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224833
06/26/10 12:59 PM
06/26/10 12:59 PM
Canada
Canada
Out cruising last night for a couple of hours....
I have no idea what temp I am running, I will have to try a mechanical gauge. my fans don't come on until the factory gauge gets into the red zone, and it feels (hand on the upper hose) OK, but I don't trust feel! haha
Kickdown is hooked up, might need a little tweak, but it's pretty good. Trans shifts good, now I have third gear at a decent speed, much better!
Steering is good, handling not bad, brakes seem OK, all in all it seems pretty drivable.
My issues are the heat- I will have to find out what I'm running at- and my fuel level gauge doesn't seem to work. I still have to get my driver's window functioning properly too. It goes down OK but needs assistance going up...
I have a new K&D sender for my water temp, I'm wondering if it's the culprit for my temp readings, maybe it reads too high?? Maybe the voltage stabilizer is off somehow? I'm not sure.
I'll have to find out what is up with my fuel level gauge- sender, gauge or wiring...
I think I'll remove my PW motor and see if the window goes up and down effortlessly in it's tracks.... I'm guessing it's binding.
I now seem to have weight transfer, maybe too much weight transfer ...? lol it squats dramatically in the rear and the front raises, it still spins but not as much and not as far. It will do a roll-on but only for a few feet usually if it's decent traction available.
I think I will have new rear leafs made. They run about $500 and I can always remove them if they don't help... or make things worse...
Still sorting out the bugs on the car, and finishing my house renos, and and and.... LOL
Body/paint will be next year at the earliest. I have a "rat rod" -ish Jensen until then! *tears*
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224834
08/03/10 10:01 AM
08/03/10 10:01 AM
Baton Rouge, Louisiana, USA
marekv8 Offline
marekv8  Offline
I am interested in how you resolve your rear suspension/weight transfer issues-- so please keep us posted on your progress. I have a 1971 Mark II Interceptor which is currently being fitted with a 499 CID stroker (built by Diamondback Engines in Texas based on a 400 block), so I anticipate having some suspension work ahead of me to handle the additional power and torque.
You've done a great job with your Jensen so far-- properly upgraded cars are so few and far between, especially in North America.
Regards, Dave
Re: Jensen Interceptor.... :p [Re: marekv8] #224835
08/08/10 06:16 PM
08/08/10 06:16 PM
Canada
Canada
Regards, Dave
Hi Dave!
I know many on the JOC forum believe in the addition of coil over springs to help the rear squat and raise the rear a little....
I am most likely going to change my rear springs FIRST, as just a quick visual inspection leaves me thinking they need replacing for sure- and once I do that I'll try and get the most out of my car as far as launching goes....
Are you using the Delta Motorsports headers?
I wound up fitting 2 1/2" exhaust right through on my car, I was warned it wouldn't fit but we got it in and it works pretty good.
I'm just driving my Jensen every chance I get and loving every minute of it for the last month or two......
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224836
08/10/10 10:58 AM
08/10/10 10:58 AM
marekv8 Offline
marekv8  Offline
Thanks for the reply!
Yes, I am using the Delta shorty headers and will need a larger exhaust with crossover section to suit it. Would you by chance have photos of your 2.5" exhaust as installed?
I'm also planning to start with new rear leaf springs and take it from there. Is there a North American source for Jensen-specific springs (other than K&D) or are you having yours custom-made locally?
Regards, Dave
Re: Jensen Interceptor.... :p [Re: marekv8] #224837
08/10/10 06:21 PM
08/10/10 06:21 PM
Canada
Canada
Regards, Dave
Killer looking mill!
I'm getting springs made locally I'm pretty sure. My buddy has a spring business and he's been begging me not to ask him.
I do have pics of the exhaust somewhere, or my brother does. It wasn't easy- I had to buy mufflers with the same outside dimension as the originals, and then I had to modify the mufflers- I cut the inlet and outlet off each muffler and I now have an S curve (so to speak) coming off each inlet and each outlet of each muffler.
I saw pics of a few Jensens that tried 2 1/2" exhaust, the rear would hit the pipe as it exited the mufflers. Took a couple hours and 4 U bends, a bit of cutting... a bit of welding, but it was doable. I toyed with the idea of an X pipe but I couldn't see it happening as far as clearance and space went.
If you were local I think I have an H pipe that bolts up to the Delta Motorsports headers.... in my shed or garage... I'm not using it.
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224838
08/10/10 06:27 PM
08/10/10 06:27 PM
Canada
Canada
Here's the muffler I started with.....
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224839
08/10/10 06:28 PM
08/10/10 06:28 PM
Canada
Canada
This is what we did to them- the only way we could get them to fit in the car.......
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224840
08/10/10 06:30 PM
08/10/10 06:30 PM
Canada
Canada
I went mandrel bends and very thick collector rings...
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224841
08/10/10 06:31 PM
08/10/10 06:31 PM
Canada
Canada
Kept it up as tight as possible....
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224842
08/10/10 06:34 PM
08/10/10 06:34 PM
Canada
Canada
I went with two mufflers at the rear, I think it sounds good but the tips are 4" at the rear- the diameter of the muffler.... I'm thinking of trying a different tip/muffler combo down the road so it looks more like a factory exhaust tip, I love the way these sound but it's a BIG diameter tip....
CrAzYMoPaRGuY
Re: Jensen Interceptor.... :p [Re: CrAzYMoPaRGuY] #224843
08/10/10 06:39 PM
08/10/10 06:39 PM
Canada
Canada
Somebody cover Oz's eyes for a second....
CrAzYMoPaRGuY
