Eddy SB heads, 340 motor ?
#2246153
02/02/17 10:18 PM
02/02/17 10:18 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
I'm putting a pump gas 340 stroker (4.0 inch stroke) motor together and I have ordered a set of Eddy part number 60179 heads and their RPM air gap intake. Have any of you on here ran those heads? If so what do you think of them? I'm asking now that it is to late for me to not use them Thanks in advance. Cab
Re: Eddy SB heads, 340 motor ?
[Re: Cab_Burge]
#2246162
02/02/17 10:31 PM
02/02/17 10:31 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I will NEVER buy another set of small block mopar hears again till they get their act together. (except the new cnc Victor head) ProMaxx heads put their's to shame and cheaper to but i don't know if they offer an open chamber head. I've gone pretty fast this the open chamber head but only after I spent a lot of hours on them. 1970 Duster Edelbrock headed 408 6.143@110.89 mph 9.73@135.05 mph shifting at 6700 RPM
[Re: Cab_Burge]
#2246172
02/02/17 10:54 PM
02/02/17 10:54 PM
Porter67
It (the 60179) has the open chamber for a positive deck height piston like a oem 340 type head. If you went flat top or dished with a quench pad at approx zero deck like most use on a stroker the pn is 60779 being the closed chamber head. The 60179 casting is a head many never pick for a small block stroker. https://www.summitracing.com/parts/edl-60779https://www.summitracing.com/parts/edl-60179 The two links show in there pics the closed chamber vs the open chamber head.
[Re: Porter67]
#2246184
02/02/17 11:12 PM
02/02/17 11:12 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Only reason I even bought the set of open chamber heads in the post above was because I bought them for 450.00 from a Moparts member after he dropped a valve. I repaired them and then installed a 2.08 valve and spent lots of time porting them. Before I put them on another engine I will be getting them cut some to jump the compression up.
[Re: Cab_Burge]
#2246513
02/03/17 02:20 PM
02/03/17 02:20 PM
fast68plymouth
So. Burlington, Vt.
IMO, the only reason to use the open chamber head is if you're building a motor that will have positive deck height.
I've always used the closed chamber version for the stroker builds I've done.
I like these heads for up to about 575-600hp builds. Beyond that, I think there are better choices...... Especially if you're paying for port work.
[Re: Cab_Burge]
#2246805
02/03/17 08:57 PM
02/03/17 08:57 PM
fast68plymouth
So. Burlington, Vt.
There is only 2cc difference between the open and closed chamber Ede sb mopar heads......65 vs 63. I doubt this will be enough to correct a build that has too much compression with the 63 version, and when you swap to the open chamber version you lose quench(if running flat tops).
There are plenty of pistons available that will work with 4" cranks and the closed chambers, and still be pump gas friendly. Icon IC745 for one.
[Re: crackedback]
#2246881
02/03/17 11:15 PM
02/03/17 11:15 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Why buy the open chamber garbage. Garbage is exactly what it is if you aren't dealing with a +.020 or more proud piston. Lose all the benefits of quench with the correct gasket. Even with a proud piston, I run closed chamber and get a proper thickness head gasket.
60779 head is the better piece for a stroker. I agree 100%. The 360 style head is the way to go.
