Re: Me and 87 octane don't play well together
[Re: quickd100]
#2246438
02/03/17 11:49 AM
02/03/17 11:49 AM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
That sounds like fun. At least you made it home, it would be no good to walk home when the temperature is 0.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2246461
02/03/17 12:30 PM
02/03/17 12:30 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
That sounds like fun. At least you made it home, it would be no good to walk home when the temperature is 0. Atleast you're out having fun w/ it!
[Re: quickd100]
#2246473
02/03/17 12:55 PM
02/03/17 12:55 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
20 psi on 87 octane? That's braver than I would ever run! Your tune must be perfect.
And nothing but 87 available? Glad I don't live where you do!
**Photobucket sucks**
[Re: quickd100]
#2246476
02/03/17 01:01 PM
02/03/17 01:01 PM
Thumperdart
State of confusion
Sorry for the damage but you've lost your mind man to even think it would live and I don't even run that crap in my Ranger and is barely good enuff for a lawn mower............
[Re: 70Cuda383]
#2246488
02/03/17 01:31 PM
02/03/17 01:31 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
And nothing but 87 available? Glad I don't live where you do! I would have 2 barrels and be taking a road trip for some 93 octane
[Re: quickd100]
#2246505
02/03/17 02:14 PM
02/03/17 02:14 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Even my bone stock 93 Dakota 3.9 pings like crazy on hills with 87.
[Re: fast68plymouth]
#2246529
02/03/17 02:34 PM
02/03/17 02:34 PM
70Cuda383
Marysville, O-H-I-O
Fix your blown plenum gasket. I bet it burns through oil like crazy too. No reason for a 3.9 to ping unless it's sucking oil from that gasket
[Re: 70Cuda383]
#2246603
02/03/17 04:18 PM
02/03/17 04:18 PM
fast68plymouth
So. Burlington, Vt.
Fix your blown plenum gasket. I bet it burns through oil like crazy too. No reason for a 3.9 to ping unless it's sucking oil from that gasket No smoke, no oil consumption(maybe a quart in 2000 miles)........ And I'm the original owner. It's pinged on 87 since day one........ 143,000 on it now. Owners manual says it should run on 87, but it's never been happy with it.
[Re: quickd100]
#2246632
02/03/17 05:21 PM
02/03/17 05:21 PM
Posts: 5,164 CT
GTX MATT
CT
One time when changing the oil on my 3100 GM V6 i broke the wire for the knock sensor. Without it it would rain detonation uphills over half throttle on 87.
[Re: quickd100]
#2247047
02/04/17 03:58 AM
02/04/17 03:58 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
Cold dry air with a high barometric readings spell death for you that day Those conditions with 24 lbs. of boost probably made well over 600 HP
[Re: quickd100]
#2247685
02/05/17 01:16 PM
02/05/17 01:16 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just kiding about the BFR loading Great info on the turbo deal! It would be interesting to know what a forged piston E85 deal like yours would do. Especiely if the motor needed no rebalance.
