Re: Real world weight loss program and it` cost..........
[Re: dvw]
#2242264
01/27/17 02:20 PM
01/27/17 02:20 PM
Thumperdart
State of confusion
I'll bet mine without the stock fuel tank is even worse. Doug I think better actually cos my trunk is flat so the air hits the back lower valance area easier and would bet that the spare tire well would direct the air away from the big azz pocket that is now wide open..............or not.............
[Re: fullmetaljacket]
#2242269
01/27/17 02:22 PM
01/27/17 02:22 PM
Thumperdart
State of confusion
DVW
Oh yeah, It's almost like having an upside down six pack scoop underneath with no escape for the wind. The amount of space between the chassis and ground is what??? 24" at best. At least a six pack scoop has open air around itself to escape up top on the hood. I could not find my drawing yesterday, but when I return from Detroit on Monday, I'll look again and post it.
Plus, both 64' and 65' as far as Dodges are concerned share the same rear bumper. It may be a little different on the Plymouth's, but not far apart. Funny you mention the 6-pack scoop cos I'm lookin at using it in the rear to deflect air away from the parachute that is the back bumper/valance............
[Re: Thumperdart]
#2242278
01/27/17 02:38 PM
01/27/17 02:38 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Yesterdays purchase.Things are moving right along.Also found the cam was installed 6* ADVANCED!
[Re: Thumperdart]
#2242280
01/27/17 02:42 PM
01/27/17 02:42 PM
hemi-itis
Will also be updating my "K". Can't get these images out of my head Goal is to get 125 lbs off the nose Thanks Doug ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
[Re: hemi-itis]
#2242348
01/27/17 04:49 PM
01/27/17 04:49 PM
Posts: 1,895 Spahn Ranch
RMCHRGR
Spahn Ranch
Al, did you weigh the cylinder heads to see what the weight difference is between the iron and aluminum? Switching to aluminum heads and rocker stands should be at least 50lbs, no? Stroker pistons will be shorter and weigh less... Wilwood discs, k frame mods, aluminum radiator, get rid of some of the chrome cup gauges on the cowl - switch out the braided steel lines for some stealth black braided stuff... easy peasy.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2242472
01/27/17 09:24 PM
01/27/17 09:24 PM
fullmetaljacket
When it comes to those chrome cup gauges and if you still intend on using them, at least move 'em indoors to the dash and push the weight more rearward. An inch rearward is good with all things.
[Re: Thumperdart]
#2242546
01/27/17 11:49 PM
01/27/17 11:49 PM
hemi-itis
After I get the heads back,I will wait till they are loaded and weigh the difference. Maybe special K could provide the iron rocker stand weight. Finding several places 0n the block to make some flakes fly! ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Thumperdart]
#2245318
02/01/17 02:56 PM
02/01/17 02:56 PM
hemi-itis
Can't really measure the chips & powdwer on the floor.But some of the larger chunks,,,,,,
[Re: hemi-itis]
#2245325
02/01/17 03:06 PM
02/01/17 03:06 PM
Thumperdart
State of confusion
It ALL adds up fast and I just removed about 12-13 lbs from trimming metal and rear valance to let air out that was getting trapped in the trunk plus the ft. rad. lower support so keep going there's LOTS left on your car.............
[Re: hemi-itis]
#2245422
02/01/17 05:48 PM
02/01/17 05:48 PM
RMCHRGR
Spahn Ranch
Can't really measure the chips & powdwer on the floor.But some of the larger chunks,,,,,, Just put a boosted small block in it and stop wasting time with that heavy lump... But that wouldn't work cause then you'd have to change your screen name to Small block-Itis. Or something like that. Isn't Dizuster's early B more door in the mid 9s with a turbo'd JY 360? I got nothing really, my car is on jack stands and will be lucky to be in the 10s.
#2245430
02/01/17 06:02 PM
02/01/17 06:02 PM
RMCHRGR
Spahn Ranch
You should be tapping on the 10's door very easily with your combo after some fine tuning and if that. Glasses is easily doing that on the brakes and he's a little less warmer than your combo.
Dzuster's car weighs 3700+ Lbs and is past a few broken parts as well, but currently flying high in cloud mid nines at a buck 40+ after so much tweaking and leaking.
Boosted, juice-ted, blew-sted, you name it, it will fly and with a different kind of care and tune as apposed to us Dyno oil burning Dinosaurs. But it makes for an interesting chat at the dinner table.LOL. Moparts match race of the century - Hemi Itis vs. Dizuster, best 2 out of 3. Loser buys the skirt steaks...
[Re: RMCHRGR]
#2245662
02/02/17 12:24 AM
02/02/17 12:24 AM
fullmetaljacket
Back to weight watching, here's an outtake from a Car & Driver teaser for the new Demonic specimen coming from Dodge. The bug has bitten the engineers hard. Welcome to the Terror dome.
"To shed some unholy mass from a Demon, Dodge ditches everything it can, starting with all the seats except one for the driver. Dumping the rear and passenger seats sheds 113 pounds, 58 of that for the passenger throne alone. (A betting man could safely wager that the seats, and their respective belts, could be available as dealer-installed options.) Ditching the trunk trim saves another 20 pounds, and 18 pounds of sound-deadening material go away, too. As we speculated, the speakers are all gone except for two small ones in the doors for the warning chimes; that and a simplified wiring harness pares another 24 pounds.
Further mass reductions compared with Hellcat-spec Challengers include ditching the parking sensors (two pounds), replacing the power tilting and telescoping steering column with a manual version (four pounds), 18-inch wheels in place of 20-inchers (16 pounds), hollow anti-roll bars (19 pounds), and the surprising choice of four-piston front brake calipers grabbing 14.2-inch rotors to supplant the Hellcat’s 16-pounds-heavier pair of six-piston grabbers and 15.4-inch rotors. (Maybe this isn’t intended as a road-course machine?)"
#2245704
02/02/17 01:34 AM
02/02/17 01:34 AM
hemi-itis
MEGA Jenny Still have hours to grind,,,,,,,,,,,,,
