Page 3 of 5 1 2 3 4 5
Re: Shopping for a new radiator [Re: mopar dave] #2245577
02/01/17 10:31 PM
02/01/17 10:31 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By mopar dave
Did you put that 28" with in an A body? Curious to how well it fit. How big are the tanks?
between the frame rails it is 29" with the lip removed at the top of the rail, the core is approx 1/2 wider ( 1/4" per side) than the opening, that a is un cut core support opening and it was a origional slant 6 car if that makes a difference in the core support, the one I ordered was 555-52018, the info says Ford but it is Ford/Chrysler and also it has NO trans cooler built in but does have a bung for a drain petcock, I am building upper and lower mounts like I have done for the other one that was in the car I think side mounts could be made also.
Re: Shopping for a new radiator [Re: madscientist] #2245586
02/01/17 10:44 PM
02/01/17 10:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By madscientist
[quote=Sport440][
Is that 19 X 31 a 26 inch core?
I don't run a shroud. The fan is close enough to the radiator to not need one.
The actual core 18.5 x 28 The 31, is to the outside of the cross flow tanks.
And IMO, doesn't matter how close your fan is to the rad, It could benefit from a shroud. up
Re: Shopping for a new radiator [Re: mopar dave] #2245616
02/01/17 11:26 PM
02/01/17 11:26 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I have a brand new A body/small block ECP radiator with dual fans and controller I'd be willing to sell. No coolant went through it. Didn't work for my particular application (don't ask, nothing to do with the radiator) so I ended up going back to my old rad and modified that instead of cutting up a new one.
I was gonna send it back but never did, just sitting in my garage.
ECP rad.
Fan controller
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Shopping for a new radiator [Re: RMCHRGR] #2245633
02/01/17 11:48 PM
02/01/17 11:48 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thanks for the offer but the hose fittings are in the wrong place. I really would prefer a cross flow after all the info i recieved.
Re: Shopping for a new radiator [Re: mopar dave] #2245681
02/02/17 12:48 AM
02/02/17 12:48 AM
Mt Morris Michigan
Mt Morris Michigan
Anyone have a linc to the guy that sells champion radiators on here. Cant find his ad.
Re: Shopping for a new radiator [Re: mopar dave] #2245684
02/02/17 12:52 AM
02/02/17 12:52 AM
Washington
madscientist Offline
Washington
I didn't think the champions were cross flow.
If you google champion radiators he comes up. IIRC he's in California.
Re: Shopping for a new radiator [Re: mopar dave] #2245686
02/02/17 12:55 AM
02/02/17 12:55 AM
Washington
Washington
I just googled it and couldn't find him.
Re: Shopping for a new radiator [Re: mopar dave] #2245700
02/02/17 01:26 AM
02/02/17 01:26 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Any thoughts on this one? Will it cool big power without weighing 500lbs?
http://www.eastwood.com/maxx-power-tri-f...UthoaArHP8P8HAQ
Re: Shopping for a new radiator [Re: mopar dave] #2245701
02/02/17 01:31 AM
02/02/17 01:31 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
There is a Griffin cross flow for sale in the race parts classifieds...
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Shopping for a new radiator [Re: RMCHRGR] #2245750
02/02/17 02:47 AM
02/02/17 02:47 AM
Mt Morris Michigan
Mt Morris Michigan
I seen that. I think the fittings are wrong. Outlet needs to be dr side and inlet on pass.
Re: Shopping for a new radiator [Re: SpareParts] #2245751
02/02/17 02:56 AM
02/02/17 02:56 AM
Mt Morris Michigan
Mt Morris Michigan
Wish i knew someone who had tried that one.
Re: Shopping for a new radiator [Re: mopar dave] #2245799
02/02/17 10:46 AM
02/02/17 10:46 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Sorry if I missed it but what is the application here? Guessing big block A body?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Shopping for a new radiator [Re: RMCHRGR] #2245813
02/02/17 11:30 AM
02/02/17 11:30 AM
Mt Morris Michigan
Mt Morris Michigan
511 filled with victor heads in a 67 barracuda.
Re: Shopping for a new radiator [Re: SpareParts] #2245814
02/02/17 11:33 AM
02/02/17 11:33 AM
Mt Morris Michigan
Mt Morris Michigan
I'm alittle afraid of that one all thou I'm not totally afraid of the double pass with 55 gal water pump. I'm currently waiting for a price from champion on a double pass just to see. its just so tempting to get a $150 crossflow, which might be enough.
Re: Shopping for a new radiator [Re: mopar dave] #2245835
02/02/17 12:22 PM
02/02/17 12:22 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Here is the one I use - fits perfect works good!
Brand:Griffin Thermal Products
Manufacturer's Part Number:8-00038
Part Type:Radiators
Product Line:Griffin Performance Fit Radiators
Summit Racing Part Number:GRI-8-00038
UPC: 766897316944
Radiator Style: Crossflow
Inlet Location: Upper passenger side
Outlet Location: Lower driver side
Radiator Material: Aluminum
Radiator Finish: Natural
Overall Width (in): 29.500 in.
Overall Height (in): 18.630 in.
Overall Thickness (in): 3.000 in.
Core Width (in): 22.500 in.
Core Height (in): 18.630 in.
Core Thickness (in): 2.680 in.
Row Quantity: 2
Transmission Cooler: No
Inlet Size: 1 1/2 in.
Outlet Size: 1 3/4 in.
Tube Size: 1 1/4 in.
Re: Shopping for a new radiator [Re: mopar dave] #2245871
02/02/17 01:34 PM
02/02/17 01:34 PM
Washington
Washington
I'm not a big fan of the cross flow and like I said, not a big fan of the multiple pass radiators. Stewart may not have been totally correct with the 16 times more pressure number but I'd bet it's not that far off.
You don't need pressure to cool the engine you need flow. Making the coolant travel further decreases flow. That is always bad.
Just hate to see you spend your money twice.
I'd call some coolant people and see what they say.
Re: Shopping for a new radiator [Re: madscientist] #2245910
02/02/17 02:27 PM
02/02/17 02:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the 2-row cross-flow Griffen for at least 14+ years and a Moroso drop in water pump and it cooled good enuff to romp in Vegas during 114+ heat and in the Hesperia Ca desert I live in. My new Moroso w/p makes it harder to come up to temp but that's a good problem to have.............REAL WORLD TESTING..........Not mag read......... beer
Re: Shopping for a new radiator [Re: mopar dave] #2245926
02/02/17 02:59 PM
02/02/17 02:59 PM
central il.
second 70 Offline
second 70  Offline
central il.
I had a 22" factory radiator in my 70 426 hemi cuda that would creep up in warm weather and traffic and replaced it with a 22" 3 row champion and it stays cool now. Fit was good only had to drill 1 lower hole. Mike
Re: Shopping for a new radiator [Re: DoubleD] #2245964
02/02/17 04:20 PM
02/02/17 04:20 PM
Mt Morris Michigan
Mt Morris Michigan
I will take a look at this tomorrow when I have some time. thanks for your info guys. I'm going to give wizard a call tomorrow to see what they have to offer as well. thanks again
Re: Shopping for a new radiator [Re: mopar dave] #2245967
02/02/17 04:23 PM
02/02/17 04:23 PM
Mt Morris Michigan
Mt Morris Michigan
I was just looking and measuring the area I have for a radiator. I have a lot of moving stuff around to fit a large cross flow in there. trans cooler and lines will have to be moved. It would be easiest if I could make a down flow work.
