Re: Vibration in 4th gear [Re: John_Kunkel] #2244955
01/31/17 09:59 PM
01/31/17 09:59 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
John I'm not sure on the bell housing,engine and trans are both 1971 dates. What are you thinking
Re: Vibration in 4th gear [Re: rowin4] #2244961
01/31/17 10:08 PM
01/31/17 10:08 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Originally Posted By rowin4
Check the rear yoke. At one time it might have kicked out a u-joint and spread the yoke. Had that happen, not real noticeable except the joint fits loose side to side causing missalignement and vibaration higher speed.
That one happened to me. had a bad u joint and it deformed the rear pinion yoke at high speeds it was noticeable at low, it was not. I've got an automatic but the problem is possible (however improbable) in both types of transmissions.
Re: Vibration in 4th gear [Re: 340swing] #2245177
02/01/17 09:35 AM
02/01/17 09:35 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
That video is interesting. I'm suspecting it's my driveshaft angle or rear end somehow. I think that will be my next step. My third member is original to the car.
Re: Vibration in 4th gear [Re: fastmark] #2245199
02/01/17 11:08 AM
02/01/17 11:08 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'm having a similar issue but it's at decel around 75 to 80. I remember having the issue last time I had the Mopar 4 speed transmission in the car.
So mine could be trans angle or driveshaft so I wanted to switch to 1350 joints and I'm getting a shaft made by Strange Engineering to replace the 25 year old shaft I've been whooping on.
64 Plymouth Savoy
Dana 60
