1970 E Body Wiper Switch #2244104
01/30/17 06:04 PM
01/30/17 06:04 PM
N. Ca.
floorit426 Offline OP
N. Ca.
Hi,
I was troubleshooting my switch, thinking it has a bad ground. That turned out to be the problem, but I noticed an open terminal on the back of the switch. Everything seems to run fine with no wire connected to it, but I am curious. Does anyone know what purpose, if any, this extra terminal serves??
Re: 1970 E Body Wiper Switch [Re: floorit426] #2244597
01/31/17 12:18 PM
01/31/17 12:18 PM
pa.
dan9 Offline
dan9  Offline
pa.
maybe for electric washers?
Re: 1970 E Body Wiper Switch [Re: dan9] #2244917
01/31/17 08:33 PM
01/31/17 08:33 PM
N. Ca.
N. Ca.
That would seem to make sense, but the washer works with the wiring as it is. Maybe this switch was designed for multiple applications? BTW, it's a 3 speed/variable setup.
Re: 1970 E Body Wiper Switch [Re: floorit426] #2245829
02/02/17 12:12 PM
02/02/17 12:12 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The 2770380 variable speed wiper switch 12 vdc power input is the B terminal. The first path the current travels is across the internal circuit breaker and the B/U is the output side of the circuit breaker and then powers the rest of the forward, park and washer functions. The B/U terminal is not used for any wiring on an E body.
However, the 2864014 three fixed speed rocker wiper switch in a 68 - 70 Charger, did use the internal circuit breaker out B/U terminal for power to drive the square washer switch to pump motor with a short jumper buried in the main dash harness.
