Delay box? #224442
02/14/09 01:34 PM
02/14/09 01:34 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
I was wondering if anyone has any pics of how they mounted there delay box in a door car. Welded up a bracket?
Re: Delay box? [Re: JandJ_Racing] #224443
02/14/09 02:07 PM
02/14/09 02:07 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
This won't do you much good but mine is mounted on the dash left of the steering wheel. Prior to this I had it mounted on a brackets where the passenger seat was. I hated it there because once straped in I couldn't reach it. So I recommend you placing it within arms reach after your all buckled in.
Re: Delay box? [Re: JandJ_Racing] #224444
02/14/09 03:03 PM
02/14/09 03:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine is mounted down near my shifter, on a alum plate
facing up on a angle so you can see it and get to it easy.
Mine is a Biondo 400 and you need to have them facing
fairly square to you so you can see it(LCD style)
Re: Delay box? [Re: JandJ_Racing] #224445
02/14/09 04:44 PM
02/14/09 04:44 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Mine is on the roll cage. I made a mount using an exhaust clamp to make the angle easy to adjust.
Re: Delay box? [Re: PLUM BAD] #224446
02/14/09 05:27 PM
02/14/09 05:27 PM
Alabama
8TREEZ Offline
8TREEZ  Offline
Alabama
Lokks nice, How do you like the ARC Wiring system you put in your car?
Re: Delay box? [Re: PLUM BAD] #224447
02/15/09 05:14 PM
02/15/09 05:14 PM
Way North Illinois
Way North Illinois
Thanks Plum Bad!
Re: Delay box? [Re: JandJ_Racing] #224448
02/15/09 05:15 PM
02/15/09 05:15 PM
Way North Illinois
Way North Illinois
Two More
Re: Delay box? [Re: JandJ_Racing] #224449
02/15/09 05:16 PM
02/15/09 05:16 PM
Way North Illinois
Way North Illinois
Re: Delay box? [Re: JandJ_Racing] #224450
02/16/09 10:21 PM
02/16/09 10:21 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Looks good. Easy to reach and see from the driver seat.
