Re: OK.... Back from vacation..... 11.50@ Norwalk... Rules help
[Re: G-Money1320]
#2242812
01/28/17 02:53 PM
01/28/17 02:53 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I like the pro tree idea, I have never done it and im sure most havent so it will be a new fun thing to raz/brag to each other about in the pits!! I did pro tree for the first time last year. It's very hard to get used to with a foot brake car, but it was really fun because it was different! I tried it first at Milan at a T&T and then the Roadkill event in Pontiac was a pro tree. I'm all for it, it will for sure mix things up. As for the razzing....you'll do that to me anyway. LOL.
[Re: B3422W5]
#2242813
01/28/17 02:55 PM
01/28/17 02:55 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
.500 pro tree 11.50 index No transbrake Two steps for stick cars only to launch No line lock use except to do a burnout, the intent is to have this be off the foot. No deep staging Courtesy staging in effect, no disqualification if you don't, but respect your fellow racer as a good sport and don't get in until both top bulbs are lit. 2 qualifying shots, at least one must be 11.50 or slower, under on both your out. I want to put this in because guys with cars that are way faster than 11.50 who will invariably enter should have it figured out to run 11.50 by the second pass in qualifying. If not, you don't get in the show.10.0 used to have this same rule, it bit me as luck would have it... No throttle stops or air shifting
I like these rules! Thanks again.
[Re: B3422W5]
#2242822
01/28/17 03:04 PM
01/28/17 03:04 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Sorry...... In the rules, I should have said guys...... And gals
My apologies DusterGirl340
[Re: B3422W5]
#2242878
01/28/17 04:02 PM
01/28/17 04:02 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sounds like you guys and girls are in for a good time. Have FUN.
[Re: OUTLAWD]
#2242880
01/28/17 04:03 PM
01/28/17 04:03 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Sounds fun. Pro tree is a challenge on a footbrake street car, but it adds to the fun. Now to find a tenth... I think it sounds like fun too, and I'll be looking for a tenth or two also. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) let see, remove front bumper, back seat,50# tool box from trunk, 1/4 tank of fuel. I\m half way there.
[Re: Mr340]
#2243013
01/28/17 08:33 PM
01/28/17 08:33 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Pro tree with a stick car can be a challenge but I'm up for it. Now I just have to plan my vacation time and get a few passes on the new drivetrain before then. Thanks again to Don for sponsoring this class it should be filled with some fast "real" street cars. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: B3422W5]
#2243018
01/28/17 08:39 PM
01/28/17 08:39 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I yanked all my belts off to run 11.66 in good air. Gonna go manual steering, electric water pump and fan. That will get me back to 11.60's. Not sure I am gonna have any more than that. Especially in summer air. I do have one secret weapon, trying my old 950 dyno carb against the pro systems 950 I bought and ran the 66 with I think the dyno carb is better.... But it's uglier.. Lol Will swap them after I get it out this spring and try back to back testing....... Maybe I will try and put Pat Norton behind the wheel, he is probably 150 pounds soaking wet, that should be a solid tenth and a half over my 310..lol
Like the others said, thanks for stepping up to support this. I ran 11.62-11.64 last year during DragWeek on pumpgas...Maybe I'll stick to the diet this year, and if I have to pour in some good gas and bump up the timing. I was planning a head swap, just not sure its in the cards this year...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: G-Money1320]
#2245073
02/01/17 12:55 AM
02/01/17 12:55 AM
B3422W5
Portage,michigan
New rule: No soaking wet 130# substitute drivers allowed!! ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Thanks Don for putting this class into the mix, it should be a lot of fun as we have watched the 10.0 guys for years enjoying!! I am gonna try to lose some weight. In fact I have to. Gonna get hip replaced this coming fall. But if I didn't have a single bite to eat before Norwalk, Norton is still a tenth and a half over me if I can snag him to drive.... Lol My car would go whew, that monster is out of the drivers seat.....
[Re: B3422W5]
#2256175
02/19/17 07:16 PM
02/19/17 07:16 PM
B3422W5
Portage,michigan
Good question Josh. Fri night sounds good, but I know a lot of people don't show up till Sat morning. So unsure what would be the best way to go. Probably lean to doing it along with 10.0 on Sat night back to back with them
[Re: dizuster]
#2259624
02/26/17 02:15 AM
02/26/17 02:15 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Damn I'm going to have to take all the boost out for the first 660ft. It's ok to run 11.50@140mph right? Lol Just curious on this one as I've never driven a turbo car but how much boost can a footbrake car make at the line
[Re: nss guy]
#2259946
02/26/17 05:00 PM
02/26/17 05:00 PM
fourgearsavoy
Rittman Ohio
How about only muffler cars? I like racing my car with mufflers but the 2-step doesn't play well with mufflers. After nearly blowing one of my mufflers up I don't run them with the 2-step anymore. But maybe with the Pro-Tree start it wont be an issue ![work work](/ubbthreads/images/graemlins/custom/work.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
