Page 1 of 4 1 2 3 4
A few questions about my transmission #2241954
01/26/17 10:58 PM
01/26/17 10:58 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
My 727 trans does not have a bolt-in sprag, I'm making an effort to make a few passes this year at the new Dragway42 so I'm thinking I really need to pull the trans and get a bolt-in sprag installed. With a stroked big block I'm scared to death of all these tranny explosions I've heard about lately.
My question is how do you guys support the motor when you pull the trans while using a motor plate? I could put a board on my jack and put it under the oil pan but it probably shouldn't sit like that for a couple weeks or so.
and last, does Lofgren still sell the 'shorty' blanket? My passenger side header is a 1/4" from the oil pan, there's no way a full size blanket is gonna fit with these headers. This is a big block A-body by the way. I just found Lofgren's number online, maybe I'll try to call tomorrow.
Re: A few questions about my transmission [Re: ProSport] #2241962
01/26/17 11:04 PM
01/26/17 11:04 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Bolt in sprag is really just a repair for a spun sprag. ( spun in the case)unless your talking about the ultimate 16 roller sprag
Re: A few questions about my transmission [Re: ProSport] #2241967
01/26/17 11:09 PM
01/26/17 11:09 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
the worthless screw jack out of my 01 Dodge Ram is suited perfectly to that very task.
Re: A few questions about my transmission [Re: ProSport] #2241968
01/26/17 11:11 PM
01/26/17 11:11 PM
aZLiViN
aZLiViN
....and I'd be more concerned about the front drum than the sprag. Aluminum or the billet steel piece for sure.
Re: A few questions about my transmission [Re: a493demon] #2241970
01/26/17 11:11 PM
01/26/17 11:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
you have to be careful those use 6 bolts and you have to drill the case for the 5th and 6th holes or just use 4 of the bolts in existing holes, also some cases have a slightly different casting and you will need a special fixture to drill the holes in those areas.
Re: A few questions about my transmission [Re: J_BODY] #2241975
01/26/17 11:15 PM
01/26/17 11:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yep,I just finished my 727 and bought every thing from CRT including the super sprag and billet steel drum, also his billet transbrake VB
Re: A few questions about my transmission [Re: ProSport] #2241977
01/26/17 11:15 PM
01/26/17 11:15 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I've used a 2x4 on the drag link under the pan to support the motor while taking the trans out.
I dont think you can get the blankets from lofgren that are cut down. Not sfi rated at least
Re: A few questions about my transmission [Re: ProSport] #2241981
01/26/17 11:24 PM
01/26/17 11:24 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks guys, the bolt-in sprag seems like kind of a pain in the butt. Maybe I'll call my trans guy and see what all it would take to get one in there.
The front drum is not gonna happen on my budget right now although I'd love to have one, I never even had one in my 9 second cars. On those cars I used a CSR carbon fiber shield on one of them, and an Ultrabell and Lofgren blanket on the other.
My trans guy is awesome, he builds a lot of transmissions for race cars at Norwalk and other tracks, he always talks me out of wasting money on an expensive front drum and his transmissions never blow up from what I've seen.
But I do know that they can, and a billet drum is a good investment if you like your legs.
My car will probably run low 11's, maybe high 10's, footbraking. It will definitely not be a weekly bracket car, I just want to make some passes and see what it runs and probably not race it anymore, but I'm leary of not having the bolt-in sprag or a blanket. shruggy
Re: A few questions about my transmission [Re: The Shadow] #2241984
01/26/17 11:28 PM
01/26/17 11:28 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
My drag link almost touches my oil pan so maybe it can just rest on that or I can put thin plywood in there? Maybe a block between the firewall and the back of the motor too. I don't want to scratch my paint but I may be able to get it in there if I'm careful.
I'm not worried about the sfi rating, just want to throw it on there for some safety for a few passes.
Re: A few questions about my transmission [Re: ProSport] #2241989
01/26/17 11:38 PM
01/26/17 11:38 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
If you undo the trans mount you'll be able to adjust it slightly up get whatever you need to pack the distance.
Installing the sprag is very easy. You dont need all the 6 bolts. I ran the 4 that are easy to drill and the sprag broke the case when it rolled
Re: A few questions about my transmission [Re: The Shadow] #2242009
01/27/17 12:22 AM
01/27/17 12:22 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
That's what I figured with the blanket, just drop tailshaft down and put the blanket up in there. As far as the sprag goes I'm just trying to make myself pull this trans and get it to my guy.
Due to a mis-communication a couple years ago the bolt-in sprag didn't get installed but that was entirely my fault but I took it home anyways because I knew I wouldn't be racing this car. Now I want to race this car. grin grin
Re: A few questions about my transmission [Re: dartman366] #2242011
01/27/17 12:23 AM
01/27/17 12:23 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
That will be a nice strong unit. up
Re: A few questions about my transmission [Re: J_BODY] #2242012
01/27/17 12:24 AM
01/27/17 12:24 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I have a couple bottle jacks but I'd need to find something tall to set it on as I have the car real high on jackstands.
Re: A few questions about my transmission [Re: J_BODY] #2242016
01/27/17 12:28 AM
01/27/17 12:28 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
That is what I use also, it will not leak down and it has a small footprint. I use the worthless Ford version because I'm not as cool as Jay
"Just a Bracket car dressed up like a streetcar"
Re: A few questions about my transmission [Re: Just-a-dart] #2242027
01/27/17 12:34 AM
01/27/17 12:34 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I use that same little screw jack from my 01 dakota for everything. laugh2
Re: A few questions about my transmission [Re: ProSport] #2242035
01/27/17 12:43 AM
01/27/17 12:43 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
How tall do those screw jacks go?
Re: A few questions about my transmission [Re: ProSport] #2242170
01/27/17 11:11 AM
01/27/17 11:11 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
The Coan super sprag is the one you want. 16 roller, about 200 bucks from Mancini. That's the first aftermarket part we add to a 727, other than a VB of course. The drum is nice too, but those are 600$, and if the sprag never fails, you shouldn't need one.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: A few questions about my transmission [Re: ProSport] #2242171
01/27/17 11:14 AM
01/27/17 11:14 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i always loosen the bolts at the motor plate at the frame just to give myself some wiggle room and not bend the plate.
Re: A few questions about my transmission [Re: ProSport] #2242181
01/27/17 11:44 AM
01/27/17 11:44 AM
aZLiViN
aZLiViN
please note the "if" and "shouldn't" in Billy's post.... Having had a close friend have the drum explode we've upgraded everything since then. Between the drive train and body damage incurred... a small price to pay... but, people been running stock stuff forever and you're not going to be hitting it time and time again, weekend after weekend. Odds are in your favor. The "other" factor in keeping the sprag happy is how good is your rear gear? The shock of breaking the rear often starts the lovely chain of events....
btw, the screw jack maxed out at 15 1/2". I do put on some blocks of wood when using it.
Re: A few questions about my transmission [Re: ProSport] #2242191
01/27/17 12:03 PM
01/27/17 12:03 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks guys.
I don't run a speedometer Cable, it looks like it's leaking a tiny amount of tranny fluid where the speedo Cable would attach. Is there a cap or something available to cap that off?
Page 1 of 4 1 2 3 4
