Re: rear leaf springs
[Re: 93moparram]
#2241595
01/26/17 12:53 PM
01/26/17 12:53 PM
RapidRobert
welcome aboard, I'm in the same boat with my 85 ramcharger sagging springs. ESPO and "springs & things" get good reviews on here. see what gets (additionally) posted.
[Re: 93moparram]
#2241599
01/26/17 01:06 PM
01/26/17 01:06 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Try to find a spring shop near you.They can either rearch and add a leaf and height.that or they should have new ones or can make them.my son had his rearched and leaf added plus 1 inch arch.his 62 sat perfect and were on at least 14 years when he sold it.my 57 had busted ones.local spring shop had them new on the shelf.Rocky
Chrysler Firepower
[Re: 93moparram]
#2241632
01/26/17 01:51 PM
01/26/17 01:51 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Buy yourself some new u-bolts and nuts and an add-a-leaf spring from a 4WD parts house. You may need longer shocks too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 93moparram]
#2241873
01/26/17 08:53 PM
01/26/17 08:53 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
93moparram has asked only to increase the height and not to increase the spring rate. You must understand if you add an extra leaf or add the Ranchero spring you will increase the spring rate.
If you only want, as you asked, to increase the height. Rearch the springs only.
To educate everyone on leaf springs. Think ofadjustable coil over springs. When you ajust the threaded collar you tune the ride height and the spring stays the same. Adding a leaf is like installing a thicker coil which will not necessarily increase your ride height. Unless it's as mention add and rearch but it will surely ruin the ride quality.
If you are using this truck to haul heavy loads a stronger spring may be what you need.
[Re: 93moparram]
#2241879
01/26/17 08:56 PM
01/26/17 08:56 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
