RV-2 #2241092
01/25/17 04:53 PM
01/25/17 04:53 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
OK, so I'm in the process of converting my old R2 a/c system on my 71 Charger to the new 134A stuff. Rebuilt the RV-2 compressor, hoses, etc. Everything is pretty much done but I'm having difficulty in finding the right suction and discharge manifold gaskets for my RV-2 compressor.
Has anyone done this and knows what gaskets work the best? Can't find the factory type. I can find fiber ones but I don't know how well they work. Do they need an additional O-ring? Or would just an O-ring by itself wok?
Any help would be greatly appreciated.
Re: RV-2 [Re: 71muffin] #2241189
01/25/17 07:32 PM
01/25/17 07:32 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I am curious too. You are at the point where I was when I gave up. Could not get the system to draw down to a good vacuum. Since I was using R-12, getting a seal was important to me.
Craig
Re: RV-2 [Re: 71muffin] #2241226
01/25/17 08:35 PM
01/25/17 08:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The originals were embossed steel, never trusted them. Composite is better.
http://www.ebay.com/itm/1961-76-Mopar-Rv2-AC-Compressor-Manifold-Gaskets-/391428860472
Re: RV-2 [Re: John_Kunkel] #2241313
01/25/17 11:22 PM
01/25/17 11:22 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Thanks for you response.
I hope you're right about the fiber ones because that's just about the only thing out there for the RV2 compressors. I've bought two and will try them. Can you tell me if they are used in conjunction with a o-ring?
71muffin
Re: RV-2 [Re: 71muffin] #2241629
01/26/17 01:42 PM
01/26/17 01:42 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Well . . . I ended up going to a local compressor rebuild shop (industrial stuff) and they had gasket material that they sold me a piece and I made a gasket from it. Not sure of the material, but it was fiberous. The A/C shop I took the car to for the R134 fill, said the system held vacuum great. They got it so you could see your breath in the air flow coming out of the vents with a/c on !!! 1970 Sport Satellite with stock RV2 system. Good luck . . .
Re: RV-2 [Re: a12rag] #2241677
01/26/17 03:15 PM
01/26/17 03:15 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Please, tell me what material they used! I've come to the same conclusion that I may have to make it myself. I've even considered dead soft copper as a gasket but if you know what the material name is, let me know so I can go buy some and get started.
71muffin
Re: RV-2 [Re: 71muffin] #2241699
01/26/17 03:42 PM
01/26/17 03:42 PM
a12rag Offline
a12rag  Offline
Ummm, not sure, that was 5 years ago !! . . . if you have a compressor rebuild shop in your area, give them a call - I am sure they will help you out.
Re: RV-2 [Re: a12rag] #2241720
01/26/17 04:21 PM
01/26/17 04:21 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Thanks. Did you also use an o-ring with those gaskets?
Re: RV-2 [Re: 71muffin] #2241737
01/26/17 04:51 PM
01/26/17 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
71muffin
No, just the gasket.
Re: RV-2 [Re: John_Kunkel] #2241786
01/26/17 06:08 PM
01/26/17 06:08 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Really? I would have thought that it would be needed even with the gasket. I'm glad to see that yours has been holding. That makes me feel a little more confident that this may actually work out.
I can't imagine that it would hurt to still add the o-ring as a backup just incase. I may also try to make a couple of additional gaskets out of some industrial type material as kind of a back up if the fiber ones fail.
Do you recall any other problems with yours?
71muffin
Re: RV-2 [Re: 71muffin] #2241903
01/26/17 09:34 PM
01/26/17 09:34 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Forget the o-ring. Just use the gasket.
- Stu Harmon
Re: RV-2 [Re: 71muffin] #2242076
01/27/17 01:37 AM
01/27/17 01:37 AM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Well, I suppose I can give it a shot without the O-rings. The initial vacuum test should tell me if the gaskets are enough without wasting any refrigerant.
I really appreciate all the information that you've given me. After all these years, there's so few who remember how things get done on these Mopars working.
71muffin
Re: RV-2 [Re: 71muffin] #2242162
01/27/17 10:44 AM
01/27/17 10:44 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I would contact an auto a/c repair shop in Florida & see what they have to offer and or say about what to use.
Just did a goggle search & found www.Omega-usa.com using key words {Chrysler rv-2 gaskets ] looks like they have some nice gaskets.
Re: RV-2 [Re: 71muffin] #2242244
01/27/17 01:38 PM
01/27/17 01:38 PM
a12rag Offline
a12rag  Offline
I just used the gasket, no o ring
Re: RV-2 [Re: 71muffin] #2242469
01/27/17 09:19 PM
01/27/17 09:19 PM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Thanks guys. I'll give it a shot and see how it goes. Still much to do besides the gaskets but this information really helps.
71muffin
Re: RV-2 [Re: 71muffin] #2242474
01/27/17 09:31 PM
01/27/17 09:31 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Years ago I called Classic Auto Air, in Tampa Florida. They sold all the gaskets to rebuild the RV2 compressor. If I recall right, they were made out of some sort of vegetable based material. It was orange or pink in color. The compressor was leak free after I replaced the gaskets.
http://www.classicautoair.com/
Ron
Re: RV-2 [Re: Ronnman] #2242577
01/28/17 12:37 AM
01/28/17 12:37 AM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
That's who I've been buying the replacement parts from. They said that they used the vegetable ones and had no problem but I wanted to makes sure since the oem compressor came from the factory with the metal ones. Go figure, maybe newer is better in this case.....
Re: RV-2 [Re: 71muffin] #2244694
01/31/17 02:38 PM
01/31/17 02:38 PM
dogdays Offline
dogdays  Offline
Chrysler used embossed metal gaskets for about everything because they were cheaper. They were masters at cutting costs.
R.
Re: RV-2 [Re: 71muffin] #2244888
01/31/17 07:51 PM
01/31/17 07:51 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Unless the flange is machined for an o-ring I don't see how you could use one. As long as the flange is clean and true you should be good to go.
Kevin
Re: RV-2 [Re: Twostick] #2245688
02/02/17 01:05 AM
02/02/17 01:05 AM
Southwest USA
71muffin Offline OP
71muffin  Offline OP
Southwest USA
Indeed, the compressor doesn't have any o ring grooves but on the low side hose mounting to the compressor, there is an o ring groove. Hi side hose doesn't have an o ring groove.
Still suggest no o ring guys?
71 muffin
