Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2241673
01/26/17 03:12 PM
01/26/17 03:12 PM
Port Huron, Michigan
MI_Custumz Offline OP
Would I still stick with 10w30 if I go to ZR-1? It's on sale for $4.99/quart right now. May buy 10 for the upcoming year. Just want to be sure to get what I need instead of wasting money or damaging something. If zinc isn't required, would it hurt the engine?
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2242639
01/28/17 02:30 AM
01/28/17 02:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My cam grinder recommended to use a good oil with alot of zinc and a small bottle of zinc additive. I have always used Valvoline VR1 racing oil and I add a small bottle of "Risoline" zinc additive. All I can say is I have only ever run flat tappet cams and I have never wiped a cam lobe. Ron
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2242642
01/28/17 02:37 AM
01/28/17 02:37 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
This thread is a good place to start: Moparts ZDDP thread
For a more in-depth read: ZDDP article
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: What is a good zinc additive for oil? [Re: 1968RR] #2242645
01/28/17 02:51 AM
01/28/17 02:51 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Only one I have used is GM EOS since the Chevy dealership always has it on the shelf. I have an engine that in all reality could do without it, but I add about 1/4 cup of it in with the 5 quarts of oil anyways.
The stuff is pretty thick compared to regular oil.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2242781
01/28/17 02:03 PM
01/28/17 02:03 PM
I don't know if I have a flat tappet cam in my engine. I bought it in 2005 and it's a 64 block. No clue as to what the internals are. I don't want to add zinc and have it mess something up. Looks like it has a bit more than conventional Valvoline 10w30, but not way up there.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2242809
01/28/17 02:47 PM
01/28/17 02:47 PM
Kirkland, Washington
Pacnorthcuda Offline
You've owned the car for 12 years and you don't know? You could simply remove a valve cover and inspect.
I don't understand your last statement "Looks like it has a bit more than conventional Valvoline 10w30, but not way up there." At all.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2242831
01/28/17 03:11 PM
01/28/17 03:11 PM
1968RR Offline
1968RR  Offline
Using a high-zinc motor oil will never damage an engine. The only things that they can harm are catalytic converters, which shouldn't be an issue for a '70 Monte Carlo.
Re: What is a good zinc additive for oil? [Re: Pacnorthcuda] #2243024
01/28/17 09:01 PM
01/28/17 09:01 PM
I'm not really good at some mechanical stuff. The price difference between ZR-1 and conventional isn't that much of a difference. I did stop by NAPA and talked to a guy in there and he said high mileage has more zinc, but according to Valvoline online high mileage (max life) has zinc/phosphorus% of .083/.077, conventional is .083/.076, and ZR-1 is .14/.13. Looks like ZR-1 has the most. I don't have the mechanical know how on lots of things, but wish I had learned more when my dad was working on cars. I usually take it to someone to get stuff done if I can't figure it out. I could call the shop that works on it and see if they know from what they've done on it. I wouldn't even know what to look for if I took off a valve cover to be honest.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2243030
01/28/17 09:14 PM
01/28/17 09:14 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Generally...the parts houses guys give out meaningless info, when it comes to zinc levels. They have no idea...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2243067
01/28/17 10:20 PM
01/28/17 10:20 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Easy solution...
As long as there ain't any cats, use an oil fortified with ZDDP...
No worries...
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2243140
01/28/17 11:47 PM
01/28/17 11:47 PM
Valvoline ZR-1 it is next oil change. Thanks.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2243152
01/29/17 12:13 AM
01/29/17 12:13 AM
Ok, one last dumb question. If I am using 10W30 now, would SAE30 be the same viscosity? I don't drive it in the winter. I bring it home in March/April and park it in October/November depending on when I can get it to the storage unit. It sits all winter and isn't started. Wife stopped at O'Reilly to look for me and they have SAE30 and 20W50. Site shows 10W30, but they don't carry it. Amazon has it for $34.77 for 6 quarts.
Re: What is a good zinc additive for oil? [Re: MI_Custumz] #2243166
01/29/17 12:47 AM
01/29/17 12:47 AM
1968RR Offline
1968RR  Offline
10W30 and SAE 30 are not the same, but you should be fine running the SAE 30.
Re: What is a good zinc additive for oil? [Re: 1968RR] #2243255
01/29/17 04:29 AM
01/29/17 04:29 AM
Washington
madscientist Offline
Washington
They are exactly the same, a 30 grade oil. The difference is as ambient temp drops, the 10w30 will act like a 10 grade oil. As the oil temp goes up, the 10w30 will GAIN viscosity.
There is no reason to ever use a single grade engine oil. Ever.
