Re: harland sharp stud kit [Re: 451Mopar] #2241081
01/25/17 04:36 PM
01/25/17 04:36 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Edelbrock, 440 source and arp have no kits for this. Edel said 3 1/4 long. Would there be any issues ordering all 10 studs 3 1/4 length? Thanks for all your help
Re: harland sharp stud kit [Re: mopar dave] #2241083
01/25/17 04:40 PM
01/25/17 04:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Yes 3 of the 5 studs are like 1/2" shorter
Re: harland sharp stud kit [Re: mopar dave] #2241090
01/25/17 04:50 PM
01/25/17 04:50 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The shorter bolt is 1 3/4" to the bolt head so a 2 1/4 to 2 1/2" would be good I think
Re: harland sharp stud kit [Re: mopar dave] #2241091
01/25/17 04:52 PM
01/25/17 04:52 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I posted this awhile back - I used these on a set of INDY EZ-1 heads
You can order ARP stuff and make your own kit - these are Summit part numbers - I just used these for my HS rockers
ARP-200-8556 WASHER 10-PC comes in a package
ARP-300-8332 12 PT NUTS 10PC comes in a package
ARP-AJ2500-1B STUD 3/8 X 2.500 – you need 6 of these
ARP-AJ3250-1B SHAFT STUD – 3/8 x 3.25 you need 4 of these
Re: harland sharp stud kit [Re: mopar dave] #2241114
01/25/17 05:20 PM
01/25/17 05:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
arp-200 is 8$
arp-300 is 13.62$
arp-aj2500-b1 is 8$ea
arp-aj3250-b1 is 7$ea
Re: harland sharp stud kit [Re: Clanton] #2241151
01/25/17 06:17 PM
01/25/17 06:17 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks guys. That makes it real easy.
Re: harland sharp stud kit [Re: mopar dave] #2241228
01/25/17 08:41 PM
01/25/17 08:41 PM
Mt Morris Michigan
Mt Morris Michigan
Looks like about $100. Gonna check with my local nut and bolt store first. Might be able to do better with just grade 8 stuff.
Re: harland sharp stud kit [Re: mopar dave] #2241353
01/26/17 12:14 AM
01/26/17 12:14 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
More threads into the heads are better, especially with the Victors.
Re: harland sharp stud kit [Re: Jeremiah] #2241383
01/26/17 12:51 AM
01/26/17 12:51 AM
Mt Morris Michigan
Mt Morris Michigan
I will be sure at least 1" of thread. How much thread is there in those bolt holes?
Re: harland sharp stud kit [Re: mopar dave] #2243920
01/30/17 01:33 PM
01/30/17 01:33 PM
Mt Morris Michigan
Mt Morris Michigan
my local nut and bolt store did not have the lengths I needed nor did McMaster carr. looks like i'll have to step up to the pay window with the ARP's.
Re: harland sharp stud kit [Re: mopar dave] #2243955
01/30/17 02:28 PM
01/30/17 02:28 PM
Mt Morris Michigan
Mt Morris Michigan
had to order from carshop performance parts. jegs and summit didn't have the 3 1/4 studs. all good with parts on the way.
Re: harland sharp stud kit [Re: mopar dave] #2244046
01/30/17 04:39 PM
01/30/17 04:39 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I looked up my McMaster order and unfortunately they no longer sell either of the following:
Line Product Ordered Shipped Balance Price Total
90281A636 Black-Oxide Steel Adjusting and Positioning Stud, 3/8"-16 Thread, 3" L Overall, 1" and 1" Thread Lengths
90281A638 Black-Oxide Steel Adjusting and Positioning Stud, 3/8"-16 Thread, 3-1/2" L Overall, 1-1/4" & 1-1/4" Thread Lgs.
I'm sure somebody still carries them if you search the hardware sites.
Maybe this will help you find something that will work:
Re: harland sharp stud kit [Re: Jeremiah] #2244175
01/30/17 08:01 PM
01/30/17 08:01 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the info. The next guy should get good direction on what he will need for fasteners.
