Re: Automatic tranny fluid
[Re: v10]
#2240186
01/24/17 12:51 AM
01/24/17 12:51 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Yes +4 ATF supersedes Dexron and ATF III in Mopar applications. Go ahead and use it.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: v10]
#2240501
01/24/17 05:13 PM
01/24/17 05:13 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
It might be just fine, but I was warned by my step-father many years ago never to mix transmission fluid since some combinations can "foam"..... for whatever that's worth.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2240566
01/24/17 06:44 PM
01/24/17 06:44 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
ok then based on the article - 1) “The previous MOPAR ATF+3® formulation was discontinued in 2005 and ATF+4® is recommended for all transmissions filled with ATF+3®.” 2)"You can use ATF+3 with all older Chrysler transmissions" then i should be able to use 4 in my 1969 727 right? and what is meant by 'shearing'??
[Re: mikemee1331]
#2240572
01/24/17 07:02 PM
01/24/17 07:02 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
then i should be able to use 4 in my 1969 727 right? While mine was leaking profusely through the shifter seal I was topping mine off with ATF+4. But it's driven VERY little. I've had the leak repaired and fluid changed, the shop filled it with a "global synthetic", I've seen the spec sheet, it's compatible with everything, including things that are incompatible with each other? Check it out: http://www.service-pro.com/documents/WarrenSpecs/WA-GlobalFullSynMulti-VehicleATF.pdf I dunno whether to leave it in there and be happy or what. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: v10]
#2240899
01/25/17 08:39 AM
01/25/17 08:39 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
There is a SAE paper on ATF+4 performance versus the three other common trans fluids http://dastern.torque.net/techdocs/nonlamp/982674.pdfIt is worth noting that ATF+4 will allow clutches to slip earlier. See Table 10 and Figure 9 This is probably only important when friction materials and clearances are worn. Other figures in the paper show that ATF+ has an improved life, and has special torque converter "shutter" characteristics.
[Re: 360view]
#2241082
01/25/17 04:38 PM
01/25/17 04:38 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you don't have a lockup converter or OD, you're wasting your money on +4.
