What las I need #2239879
01/23/17 05:23 PM
01/23/17 05:23 PM
mississippi
bentwheel43 Offline OP
mississippi
I have a 511" with Eddy RPM head. The cam card has .016 in. and .018ex. what should I set them at.
Section 8 Racing We are nuts about racing.
Re: What las I need [Re: bentwheel43] #2239985
01/23/17 08:31 PM
01/23/17 08:31 PM
Try .010 and .012 cold (.006 tighter cold)and then check them with the motor hot to see how much they end up at, adjust accordingly up scope
Re: What las I need [Re: Cab_Burge] #2240047
01/23/17 09:50 PM
01/23/17 09:50 PM
mississippi
mississippi
so it is tighter with the aluminum heads. thanks Cab It is a street roller cam.
Re: What las I need [Re: bentwheel43] #2240077
01/23/17 10:33 PM
01/23/17 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Alum heads grow more than a iron head so you
gap them tighter.. myself I use .004 as a
growth factor.. try .004 -.006 cold then check
them when hot.. you only need to check a couple
EDIT
I was running E-85 so the temp didnt get as high
as a normal gas burner... just check your hot lash
wave
Re: What las I need [Re: MR_P_BODY] #2240091
01/23/17 10:50 PM
01/23/17 10:50 PM
mississippi
mississippi
Thanks Mike, so I am looking for .016 &..018 hot right?
Re: What las I need [Re: bentwheel43] #2240100
01/23/17 11:00 PM
01/23/17 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats good with those numbers.. I usually run
a bit on the tight size but you have a tight
lash cam already
wave
