Re: Who makes these roller rockers? [Re: SoCalRacer] #2226462
01/03/17 06:08 PM
01/03/17 06:08 PM
San Diego, USA
SoCalRacer Offline OP
San Diego, USA
Not a real big cam..... flat tappet 292 @ .020/.600" with 1.5 rockers, but with the 1.6 it's .640" lift and whatever duration changes that causes. Springs are 170 lbs. on the seat, 354 lbs/in, so a little over 390 open.
If it ain't broke ... you're not pushing it hard enough.
Re: Who makes these roller rockers? [Re: SoCalRacer] #2226557
01/03/17 08:36 PM
01/03/17 08:36 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I had to replace a set on a 440 I used to own. They were used with a mild 238@.050/.555 street roller and this what a mess they made...The springs were off and probably lash too, but still what a mess. Day one of car ownership at that.
I would not use these rockers with a stock hydraulic cam
2 kids and a dog
Re: Who makes these roller rockers? [Re: SoCalRacer] #2226595
01/03/17 09:23 PM
01/03/17 09:23 PM
San Diego, USA
San Diego, USA
I've already ordered a set of Harland Sharps. Can't risk a motor over trying to cobble together a set of these cheap ones. I looked at the T&D, but I didn't want to also have to get new pushrods, since they only offer cup adjusters requiring a ball on both ends and mine are ball/cup like traditional Mopars.
Re: Who makes these roller rockers? [Re: SoCalRacer] #2226598
01/03/17 09:25 PM
01/03/17 09:25 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Good call. up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Who makes these roller rockers? [Re: SoCalRacer] #2226603
01/03/17 09:32 PM
01/03/17 09:32 PM
Washington
madscientist Offline
Washington
Should go without saying, but make sure you check your geometry.
Go to b3racingengines.com and read all the tech pages.
The chances your geometry will be correct is near zero.
Re: Who makes these roller rockers? [Re: TonyS451] #2226789
01/04/17 12:16 AM
01/04/17 12:16 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Dang Tony!!!
Don't feel bad....... But I got a pretty good chuckle out of that pic laugh2
Re: Who makes these roller rockers? [Re: fast68plymouth] #2227130
01/04/17 03:10 PM
01/04/17 03:10 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Dang Tony!!!
Don't worry Dwayne, I can laugh now too! I kid you not, I picked up the car (70 Superbee), brought it home from Ohio, took the family out for a drive to show off my new toy - and all of a sudden lots of loud sounds from under the hood. Turned out to be a good car, but I really thought I had been taken. Picked up a set of Hughes rockers and correct valve springs, replaced a valve, and never had another issue. Previous owner helped with the cost too, so that was good.
Still, will never touch a cheap rocker - ever again. Ill use stock stamped before I would touch that garbage.
2 kids and a dog
Re: Who makes these roller rockers? [Re: SoCalRacer] #2227147
01/04/17 03:23 PM
01/04/17 03:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Those cheap rockers are nothing more than a waste of raw materials.
Re: Who makes these roller rockers? [Re: madscientist] #2228008
01/05/17 06:52 PM
01/05/17 06:52 PM
San Diego, USA
San Diego, USA
"Chances your geometry will be correct is near zero." BINGO! That has been my experience with most every engine I've built.
Thanks for the resource - can never know too much, and I always regard what I read on a Mopar specialist's site with more respect. Real-world experience always trumps academics or Brand-X generic info. It sounds like he subscribes to Jim Miller's "Mid-Lift" theory for rocker geometry. I read Miller's stuff a few years ago and he makes a compelling argument for the "1/2 lift" geometry. Sometimes it's tricky to get that with assorted parts and a shaft system, but it's what I try for.
Re: Who makes these roller rockers? [Re: SoCalRacer] #2238676
01/21/17 10:06 PM
01/21/17 10:06 PM
San Diego, USA
San Diego, USA
Just to follow up, the pushrod length and rocker geometry with the Harland Sharp 1.6 rockers is pretty darn good. The roller area is centered on top of the valve and measures .120" travel. Checked on a few, but here's one:
Re: Who makes these roller rockers? [Re: SoCalRacer] #2238756
01/22/17 12:15 AM
01/22/17 12:15 AM
USA
B3RE Offline
B3RE  Offline
USA
With .640" lift and the HS rockers, you shouldn't have more than .040" sweep. A 300% error in geometry is not going to be good for the valvetrain.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Who makes these roller rockers? [Re: B3RE] #2238769
01/22/17 12:35 AM
01/22/17 12:35 AM
USA
B3RE Offline
B3RE  Offline
USA
I just did a few more calculations. Increase your net valve lift to 1.184", and the geometry will be perfect. Fwiw, you would have been better off to spend the extra money on pushrods, and got rockers with a better design, IMHO.
Mike Beachel
Re: Who makes these roller rockers? [Re: SoCalRacer] #2238802
01/22/17 01:13 AM
01/22/17 01:13 AM
Washington
Washington
It's centered, but as mentioned it's way too wide.
That needs to be corrected.
Re: Who makes these roller rockers? [Re: madscientist] #2239000
01/22/17 02:33 PM
01/22/17 02:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
T&D refused to install a solid bushing on mine when they were in for a rebuild.
Re: Who makes these roller rockers? [Re: madscientist] #2239112
01/22/17 04:40 PM
01/22/17 04:40 PM
Years ago the suggested perfect sweep from the Mopar drag race engineers at thier drag race seminars was from the inner third of the stem at closed to the outer third of the stem at max lift on both 3/8 and 5/16 valve stems shruggy work
That was with ductile iron rockers also work shruggy
Re: Who makes these roller rockers? [Re: Cab_Burge] #2239188
01/22/17 05:42 PM
01/22/17 05:42 PM
USA
B3RE Offline
B3RE  Offline
USA
Yes Cab, that advice would produce the least amount of scrubbing action on a ductile iron, or any, non roller tip rocker. It's a completely different animal with a roller. With a non roller, the contact point between the valve and rocker moves from the inside to the outside of the rocker tip. On a roller, it is always in line with the roller axle centerline. Mock them up side by side, and run them through a lift cycle. The geometric differences are very noticeable.
Mike Beachel
Re: Who makes these roller rockers? [Re: jbc426] #2239237
01/22/17 06:28 PM
01/22/17 06:28 PM
Washington
Washington
I don't think they will bush a rocker that was already machined for a bearing. They will sell them without a bearing, or with a bushing if you [censored] loud and long before you order them.
Re: Who makes these roller rockers? [Re: B3RE] #2239355
01/22/17 09:01 PM
01/22/17 09:01 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I'd argue that the exact same effect occurs with roller tip rockers but that the effect is greatly reduced due to the MUCH tighter radius on the roller wheel vs. the OE type rocker pad. The line from the contact point to the roller axle is only at a right angle to the line from the center line of the rocker shaft to the roller axle at one point of lift.
Re: Who makes these roller rockers? [Re: B3RE] #2239409
01/22/17 10:27 PM
01/22/17 10:27 PM
I'm not trying to hijack this thread on the rocker tip sweep pattern but in the interest of learning some more about this I just went out into my shop this afternoon to check the sweep pattern and width on one of my new HP bracket motors.
It has a Jesel paired rocker arm kit on a set of Indy 440-1 heads with lash caps, the sweep width is right at .130 wide using a set of dial calipers to measure that, it is almost perfectly center on each side of the valve stem tip and the lash cap oil hole in the center shruggy
I did set them up like the instruction say from Jesel using shims under the tool steel adapter mounting bracket to the heads to get the geometry the way they want it shruggy
I used a set of Manley .080 thick harden head bolt washers as shims after talking to their tech. rep., Jesel does offers their shims in .025 increments so maybe using a .025 thicker or thinner spacer might make the sweep patter better or worse confused shruggy
I'm going to run what I have for now on this motor and maybe later, if I get a burning desire to test, I'll experiment with the stand height shims thicknesses to try and make it better work
I keep thinking that the roller wheel on the end of the rocker arm needs to move, roll, to avoid destroying itself from galling from lack of motion confused work
