Re: 727 Trans question
[Re: CARMAN]
#2238649
01/21/17 09:15 PM
01/21/17 09:15 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Light throttle 2-3 upshift at 40 mph is way too late, stock is around 15 mph. Stock carb or aftermarket? If aftermarket does it have the correct Mopar throttle lever extension?
If so, try disconnecting the linkage and let the trans lever come full forward....drive it easy and see if it downshifts coming to a stop. If it doesn't it's either a governor or shift valve problem.
[Re: CARMAN]
#2240374
01/24/17 01:19 PM
01/24/17 01:19 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
1-2 upshift should be 15mph, 2-3 upshift 24-25mph, under light throttle, then you'll have proper downshifts. A 2-3 upshift at 15 is way too early.
Facts are stubborn things.
[Re: CARMAN]
#2241619
01/26/17 01:23 PM
01/26/17 01:23 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I don't get that! 3rd by 11mph acceptable? I would think that would burn up a trans. I've always had my set for 1-2 shift at 11-15mph, and the 2-3 at just before 25mph at light throttle, on my small blocks with 3.2 gears.
This said, I stand corrected but confused.
[Re: larrymopar360]
#2241645
01/26/17 02:18 PM
01/26/17 02:18 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
This said, I stand corrected but confused. Note that it states "Closed Throttle" for those specs--BIG difference tween closed throttle and light throttle. I'm diggin the upper spec for a hemi 2-3 upshift at 93mph full throttle!!!
[Re: Pacnorthcuda]
#2241746
01/26/17 05:03 PM
01/26/17 05:03 PM
John_Kunkel
Rio Linda, CA
For the sake of that chart "closed throttle" is light throttle. If the throttle were actually closed how could the car attain 10 mph?
[Re: John_Kunkel]
#2241752
01/26/17 05:15 PM
01/26/17 05:15 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
John Kunkel, Not to hijack, but a question I've had for you for years...I like my forward pattern /stock overhaul MVB in my Clonerunner, BUT I always wondered at the freewheeling 1st gear.(Think this one is a cheetah) I know you can frag the sprag if you are not careful when you get back on it from a roll, but WHY is that done for racing,(like does the MVB HAVE to be built that way?) and IIRC some MVBs now have coast braking in 1st? Thanks, Bear
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: Sixgun]
#2241813
01/26/17 07:18 PM
01/26/17 07:18 PM
John_Kunkel
Rio Linda, CA
The original RMVB was a Mopar engineering idea and the absence of rear band apply (freewheeling in 1st gear) was probably for convenience but was also considered a performance benefit because there was no overlap on the 1-2 upshift.
Nowadays MVB's can be built with or without rear band apply.
[Re: CARMAN]
#2242205
01/27/17 12:38 PM
01/27/17 12:38 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yea, I'm likin the 2-3 at 93 also! Closed throttle is light throttle, isn't it?
[Re: larrymopar360]
#2242220
01/27/17 12:57 PM
01/27/17 12:57 PM
Pacnorthcuda
Yea, I'm likin the 2-3 at 93 also! Closed throttle is light throttle, isn't it? I think the term "light throttle" is so vague that its almost useless. Yes the tranny should shift at relatively (another vague term) low mph with a barely cracked throttle (trying to be more specific...LOL). A car will shift to 3rd just idling down a slight grade at a very low mph.
