Will wheel covers fit on rallye wheels? #2236633
01/18/17 12:28 PM
01/18/17 12:28 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
OK, I know this is an odd question. I like my 15x7 rallye wheels. I have always wanted to put the 15" wire wheel covers on to have a day 1 look as well. I don't have any wheel covers to try. I'm guessing the rallye center section would not allow the seating of the wheel cover but I wanted to ask the question anyways. Can anyone help with this weird/stupid idea? Will the fit? Thanks, Mark
Re: Will wheel covers fit on rallye wheels? [Re: rutro] #2236647
01/18/17 01:09 PM
01/18/17 01:09 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
If you take the centre hub out, it might work. Can't really see why it wouldn't.
Re: Will wheel covers fit on rallye wheels? [Re: rutro] #2236665
01/18/17 01:43 PM
01/18/17 01:43 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Should fit fine . You will probably need to remove the center caps first. The rim of the wheel is like a plain wheel. I put a set of stock 64 Sport Fury full hubcaps on 14 inch rallye wheels.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Will wheel covers fit on rallye wheels? [Re: doctor_mopar] #2237329
01/19/17 05:02 PM
01/19/17 05:02 PM
Allen, TX
rutro Offline OP
rutro  Offline OP
Allen, TX
Thanks for the response guys. I will have to try it with one junk one before I spend the money on a nice set. Mark
