Page 2 of 4 1 2 3 4
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2052373
04/12/16 12:04 AM
04/12/16 12:04 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ha ha...I just caught this thread. Mine made around 80-100 passes in 9.90 form last year, as well as lits of street driving.
Still learning, but something happened and it nipped the piston. Either the plug damage, too lean, or too much boost. I'll take the blame for the tuneup, but it wasn't the parts fault.
Just about back togetter with a new slug ready for BRACKET RACE season and terrorizing the neighborhood.
Mag'd the cast crank and checked it for straightness...good to go!
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2052382
04/12/16 12:10 AM
04/12/16 12:10 AM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
8.93@149
3.23 geared 8 3/4
5.7 Hemi 88mm turbo
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2052427
04/12/16 12:35 AM
04/12/16 12:35 AM
Amherst,NY
challengermike Offline
Amherst,NY
Last year I blew the 4.30s I had in my car and put 3.23s I had laying around and my 60ft was still the same 1.50 and the et was still the same, usually 6.9 to 7.2s. That's in an 72 dart with a 499 with a 3,200 stall. I did put shorter tires on 275/50 15 in place of the 295/65 15s. I was shocked to find out it ran exactly the same.
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: BSB67] #2053112
04/12/16 10:05 PM
04/12/16 10:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By BSB67
Car in sig is kinda close. Not low 11's, but mph suggests it has potential. I think it is reasonable to think my car with a 2400 rpm converter, headers, and a 200 lb. car diet would put it in the low 11's.
The car's 60 ft is 1.90 sec, and the converter won't stall past 1800/1900 rpm.
you dont need headers or a diet........put a converter in it low 11s no prob with 120mph.i bet it would be in the 10s with all the above.what cam u running?
Thanks. You are probably correct, I just didn't want to sound too presumptuous.
I agree as you have the power for 11.0's at 120 mph. Conveter and some chassis tuning and you could be in the very low 11's. up Ron
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237186
01/19/17 11:32 AM
01/19/17 11:32 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I just found this thread, and it gives me hope! Thinking about taking my Duster to the track this year with 3.23 gears, 28" drag radial, and 9.5" converter.
Do any of you know your trap rpm?
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: GY3] #2237191
01/19/17 11:44 AM
01/19/17 11:44 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Originally Posted By GY3
A little update. My car ran an 11.30 @ 119.8mph this weekend.
The mph says I have an 11.0 waiting on me if it ever hooks well!
Whittled down to an 11.1 @ 121 mph end of last season. Trying to resolve rear suspension issues.
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237234
01/19/17 01:40 PM
01/19/17 01:40 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah, I like this thread. Right now, the parts I have are pointing to me building a 451 low deck for my 67 coronet. Thinking about the heads right now and was wondering if the 240cc (trick flow or cnc promaxx) would be too much volume.
I see some guys with cnc stealths in this thread so I guess the ported heads would be ok. That leaves me with the possibility to step it up to a large cam and more gear if I decide I want to get more serious about haulin ass...
I'm thinking 3.55 gears are the sweet spot...BUT, I have a 2.94 sure grip in the car now so maybe I would setup a 3.91 third member and if I want to take a longer trip just swap the 2.94 gears in...idk.
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237243
01/19/17 02:01 PM
01/19/17 02:01 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
2.94's would be sweet on the highway. I don't care for my 3.23's on the highway but most guys wouldn't mind it at all. I had 3.55's and hated them but they'd be better on the strip.
Go for the better Heads so you have room to grow. My motor is a pump gas 500" with CNC max wedge Edelbrock's. It has a small cam and small headers, seems to have alot of torque so I'm hoping to hit high 10s or low 11s driving to and from the track.
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: OUTLAWD] #2237330
01/19/17 05:03 PM
01/19/17 05:03 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted By OUTLAWD
Not low 11's but 11.50 @ 116
66 Belv. 493, -516 iron heads, .530 cam, 9.5" converter, 3.55's and a 28" tall tire. I have a plate on it but have yet to open the bottle up. The converter is probably a bit loose, but I expect high 10's with a relatively small shot.
I ended up hitting the Belvedere with a 0.051 N2O jet. It ran a string of 10.95-10.98 once I got the timing where I wanted it, before I got a talking to for no roll bar tsk
It had a 10.8x in it, but the track was going away and they shut it down before I could get the launch sorted
Car is 3700# at the line.
I basically use it as a daily driver during the 2 month MI summer...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237345
01/19/17 05:44 PM
01/19/17 05:44 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I have been 9.70 with my 493 at 3300 lbs with 3.55 gears, this combo would have went 9.50s but decided to change directions without ever getting the slip
I have been 9.88 with 426 g3 at 3240 lbs with 3.55 gears
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: Dave_S] #2237386
01/19/17 06:44 PM
01/19/17 06:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Dave_S
8.93@149
3.23 geared 8 3/4
5.7 Hemi 88mm turbo
Impressive, sure would love a car like that in my garage. up
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: sixpackgut] #2237394
01/19/17 06:55 PM
01/19/17 06:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very impressive Ray. What RPM do you trap at? 275/60/15?
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ProSport] #2237515
01/19/17 09:28 PM
01/19/17 09:28 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Im thinking both combos are under 6800. Ive have either 325/50 or 295/55 on my car
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: OUTLAWD] #2237520
01/19/17 09:37 PM
01/19/17 09:37 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Awesome! I thought about doing this for the upcoming season as well. What did you set your total timing at? Did you change spark plugs to a different heat range?
'63 Dodge 330
11.19 @ 121 mph
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: sixpackgut] #2237584
01/19/17 11:40 PM
01/19/17 11:40 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
With a 28" tire, 3.55's, and a mph of 136 I'm getting only 6000 RPM's, which sounds about right to me. Are you running naturally aspirated?
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237595
01/19/17 11:49 PM
01/19/17 11:49 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
11.57@116.2
4,008 pounds
3.23
93 pump gas
9x28 M/T pro bracket radial
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: SILVER67] #2237631
01/20/17 12:29 AM
01/20/17 12:29 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have been 10.91 with 3.54 gears but my 5-speed has a 3.37 low gear so that makes for a nice mechanical advantage. I will be interested to see how the car reacts with a 4.10 gear and a 2.66 low gear in a stock HEMI box.
Last time out I was driving through the clutch which was indicated by the 126 MPH. with an 11.09 ET. Someday I will get my clutch tuned but I don't spend enough time at the track to get it dialed in on kill.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: challengermike] #2237648
01/20/17 12:49 AM
01/20/17 12:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It seems with the torque alot of the strokers have they run fast with not as much gear. And the shorter tires is like putting a high number gear in so that may have also helped keep the et about the same. Ron
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ProSport] #2237732
01/20/17 03:40 AM
01/20/17 03:40 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
NA. My 493 was 140mph. The 426 135
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2237743
01/20/17 08:16 AM
01/20/17 08:16 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Page 2 of 4 1 2 3 4
