Re: Dead stock 440 & 400 1/4 miles times?
[Re: 70dusterjohn]
#2237189
01/19/17 11:37 AM
01/19/17 11:37 AM
Posts: 4,804 Wichita
GY3
Wichita
Lots of different compression ratios between the two engines throughout the years. Heads too.
On a 9.5:1 440 with mild cam, headers and 750 Holley, I ran 104mph at 3,640 lbs. with 3.23 gears. Stock cast iron intake and 452 heads!
High 12's low 13' with a freshened stock 440 under 4000 lbs. is pretty easy.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: doba]
#2237236
01/19/17 01:46 PM
01/19/17 01:46 PM
Posts: 360 Ohio
shorthorse
Ohio
[Re: doba]
#2237254
01/19/17 02:14 PM
01/19/17 02:14 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Have a bone stock '77 440 out of a 1 Ton Van in my Charger. Low compression, stock intake, original thermoquad, HP manifolds, 2 1/2" TTi exhaust, 3.23 Sure grip Went 14.91 @ 90+ mph, no idea what it weighs or weather conditions Article I read somewhere, factory performance claim for a '71 4 BBL 440 Charger ran 14.50
[Re: roadhazard]
#2237259
01/19/17 02:27 PM
01/19/17 02:27 PM
Posts: 3,249 Between a rock & a hard place
cudadoug
STOCK 72 Duster. late model smogger 440, untouched from the boneyard.
67 915 heads, stock. 67 stock iron intake.
Thermoquad
Stock, stock, stock.
Oh it did have 1 7/8 fenderwell headers and exhaust to the rear end.
3.23 gears, with a 255 Dunlop Qualifer.
Newly built ran 13.60's @ 103. Working on the tune up, front and rear suspension, adding frame connectors, etc...got it to 13.30's.
I miss that car..
[Re: doba]
#2237293
01/19/17 03:25 PM
01/19/17 03:25 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Stock 440 in my 72. Well it did have some 2295s in it, but I didnt find till much later they were in it. Motor was worn beyond belief. Didnt have squat for compression. 2 lbs of OP at idle when hot.
CH4B intake, 750 Eddy untouched, small tube headers. 3.23s. Ran 14.01 @ 98.46 on basic radial tires. Had to walk it out of the hole.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: doba]
#2237327
01/19/17 04:56 PM
01/19/17 04:56 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
back in the 80s early 90s I had a 76 Newport with a 400. The car didn't have cats on it. I worked the thermoquad and it ran right with the stock mustangs and monte carlo ss. I took it to the track a few times and I'm thinking it ran very low 15s. Most fun car I ever had
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: doba]
#2237333
01/19/17 05:10 PM
01/19/17 05:10 PM
Posts: 2,261 IL
furious70
IL
69 Coronet - 3600lbs with me magnum 383 with 750 Holley and headers, 3.91's 14.30 same car but torker+2" spacer, no ps, 7" slicks, 3000 stall 13.20 how I tried to get 12.99 out of that!
69 Charger, also around 3600lbs laden IIRC stock 440 with 750 vac sec and headers, 3.23's 14.02 IIRC That car was no quicker with 4.10's with the stock cam and such
70 Sport Fury 4200lbs the same magnum 383 with 750 Holley and headers, 3.91's as the Coronet had earlier 14.12 leaving off idle on 225/75/15's. That was a mine shaft day and it was never close to that time again =)
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: doba]
#2237352
01/19/17 05:56 PM
01/19/17 05:56 PM
Posts: 5,173 CT
GTX MATT
CT
I love these types of threads, 13.20s in your buddies Dodge was cooking
[Re: doba]
#2237437
01/19/17 07:43 PM
01/19/17 07:43 PM
Von
NE Oklahoma
A buddy who is a member has a 68 Sat with basically a stock 440. Idk what year of motor. No compression to speak of, I do know that. Does have a 292 Comp cam. 750 DP. Headers. 3.23s I think he went 12.20s or 30s.
[Re: doba]
#2238047
01/20/17 06:49 PM
01/20/17 06:49 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Were factory tolerances that sloppy that ETs are that far apart? One B body ran low 13s while another ran mid 15s? Surely a Couple points of compression aren't worth 2.5 seconds
**Photobucket sucks**
[Re: 70Cuda383]
#2238177
01/20/17 11:27 PM
01/20/17 11:27 PM
cudadoug
Were factory tolerances that sloppy that ETs are that far apart? One B body ran low 13s while another ran mid 15s? Surely a Couple points of compression aren't worth 2.5 seconds Could be. Mopar tolerance on all assemblies could be give or take 1/2 of an inch! Also consider the diff in drivers...race ready weights, weather, track conditions, etc. It's totally apples and oranges.
