Quick Need 727 Help
#223617
02/13/09 06:53 PM
02/13/09 06:53 PM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
Hey I need some help....I got the "Build it yourself 727 Video" So I watched it a few times and im feeling pretty confident and everything is going smooth until it comes time to hit tap on the input shaft with a rubber mallet so the pump falls out.....Yeah right is there some sort of trick to this. I removed All the appropriate snap rings, bearing, governor, pump bolts and it should just tap out right?
I have built a few motors so I figured hey why not a trans? Am I nuts? What is keeping the pump and drums from sliding out?
1965 Belvedere II 440 4psd 4.10 Driver
1966 Belvedere II Race Car Project
1970 Duster Street Car Project
2003 Hemi Ram Quad Cab 4x4
Re: Quick Need 727 Help
[Re: Mr Bojangles]
#223618
02/13/09 07:00 PM
02/13/09 07:00 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you are refearing to removing the pump housing from the case there are 2 bolt holes that have threads for a 3/8's bolt. use a long bolt and thread them into the housing a little on each one to press the housing out of the case.
No required
[Re: WILD BILL]
#223619
02/13/09 07:08 PM
02/13/09 07:08 PM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
I have seen by buddy use a slap hammer to remove the pump from the front like that... What im trying to do is bang on the output shaft while the trans is pump side down. "In the video" he taps it and the pump and frond drum just falls out so nice.....?
[Re: Mr Bojangles]
#223620
02/13/09 07:16 PM
02/13/09 07:16 PM
WILD BILL
BROOK PARK, OH
All I ever do is use long bolts and thread them into the pump housing a little at a time on each one. Works great every time and the pump comes out in a nice controlled fashoin.
[Re: Mr Bojangles]
#223622
02/13/09 07:29 PM
02/13/09 07:29 PM
Posts: 5,080 organ
maximum entropy
organ
slide hammers are the preferred method. you can also use two bolts and a piece of chain, slip a bar through the chain and tap on the bar. if you thread bolts all the way through the pump you run the risk of damaging the case. it's also helpful to tighten the front band before pulling the pump so the guts don't come spilling out in an uncontrolled manner.
[Re: maximum entropy]
#223623
02/13/09 07:32 PM
02/13/09 07:32 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
[Re: Dodgem]
#223626
02/13/09 10:56 PM
02/13/09 10:56 PM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
The pump is frozen in there....Has this ever happened to anyone else??? I tied a slap hammer and welded up a puller like Dodgems and still no luck. It bent the angle iron!! In thinking there has got to be something holding it in there but I triple checked it and see nothing. So i soaked it with liquid wrench and in the morning im gonna go and get stronger angle and try it again.
[Re: dOoC]
#223628
02/13/09 11:05 PM
02/13/09 11:05 PM
Posts: 32,954 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
You screwed the bolts into the two threaded holes in the pump and not into the case right? Can you post a pic of what you have setup?
[Re: stumpy]
#223629
02/13/09 11:08 PM
02/13/09 11:08 PM
WILD BILL
BROOK PARK, OH
What size bolts are you using?
[Re: Dodgem]
#223632
02/14/09 12:22 AM
02/14/09 12:22 AM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
It threads nicely with no problems. Just when I crank down on it it didn't budge.
[Re: Mr Bojangles]
#223633
02/14/09 12:25 AM
02/14/09 12:25 AM
WILD BILL
BROOK PARK, OH
are you sure you got all the bolts out?
Don't laugh, it's happened
[Re: Dodgem]
#223635
02/14/09 11:42 PM
02/14/09 11:42 PM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
Yup...Im letting it soak till tomorrow. I have to learn how to resize pics....uggg
[Re: Mr Bojangles]
#223636
02/15/09 12:06 AM
02/15/09 12:06 AM
WILD BILL
BROOK PARK, OH
Try this
