Re: R12 to R134a kit
[Re: 71muffin]
#2235571
01/16/17 08:37 PM
01/16/17 08:37 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I converted my 92 D250 to R134. It doesn't cool as well as it did with R12. The work was done nearly 15 years ago and I've been all over it numerous times. It just doesn't do the job as well.
I thought about going to 134 on the Imperial but the 12 cools much better than 134 in my truck. I have no interest in messing with that.
[Re: feets]
#2235588
01/16/17 09:03 PM
01/16/17 09:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I thought about going to 134 on the Imperial but the 12 cools much better than 134 in my truck. I have no interest in messing with that. A 92 doesn't have an RV2 compressor or the same expansion valve. You are probably running an R12 expansion valve and need an R134 one to make it work right. My 87 Diplomat I converted to R134 and it cooled ok, not as good as R12 though. Wife's 96 Neon came with R134 and would make your joints ache it got so cold. Noticed that both used what appeared to be the same, physically anyway, expansion valve, so I put a Neon one in my Diplomat and it really helped. You may consider that for the truck. I eyeballed the pictures at RockAuto and they look similar enough to maybe swap.
[Re: Supercuda]
#2235611
01/16/17 09:40 PM
01/16/17 09:40 PM
feets
Senior Management
Senior Management
Irving, TX
I thought about going to 134 on the Imperial but the 12 cools much better than 134 in my truck. I have no interest in messing with that. A 92 doesn't have an RV2 compressor or the same expansion valve. You are probably running an R12 expansion valve and need an R134 one to make it work right. My 87 Diplomat I converted to R134 and it cooled ok, not as good as R12 though. Wife's 96 Neon came with R134 and would make your joints ache it got so cold. Noticed that both used what appeared to be the same, physically anyway, expansion valve, so I put a Neon one in my Diplomat and it really helped. You may consider that for the truck. I eyeballed the pictures at RockAuto and they look similar enough to maybe swap. I've been down that road. Throwing parts at it over the years hasn't fixed it. It cools well enough. I had the fan on high and was comfortable when driving through Needles on a 117 degree day. The truck cooled better with 12. Systems designed for 134 work great with it. For some reason the conversions just don't quite seem to do as well.
[Re: 71muffin]
#2235747
01/17/17 12:34 AM
01/17/17 12:34 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
It depends in part on the condenser that came from the factory... When the compressor seal went on my '84 F-150, since I had to put a new compressor and receiver dryer on it anyway, I converted it to R-134a. I stay cool and comfortable in southern MO heat/humidity (frequently 90/90 in August)... the old Ford has a huge condenser and lots of airflow through it. For those who don't want to convert, a mix of propane/butane (available commercially as "Duracool 12a") is a drop-in replacement for R-12, although illegal in some states. No penguin-unfriendly ozone depleting potential and very cheap to make, so Dupont-funded lobbyists did their best to suppress it.
[Re: 71muffin]
#2235825
01/17/17 02:29 AM
01/17/17 02:29 AM
Supercuda
About to go away
About to go away
up yours
So does propane if you want to get down to it.
[Re: feets]
#2235901
01/17/17 09:51 AM
01/17/17 09:51 AM
Posts: 1,794 Greer, SC
TooMany62s
Greer, SC
I thought about going to 134 on the Imperial but the 12 cools much better than 134 in my truck. I have no interest in messing with that. I added the complete factory AC system from an '87 to my '84 pickup and converted to r134 at that time. The system worked but not all that well. When the compressor died years later a technician friend of mine advised that the system would work much better if I changed to a condenser that was designed for r134. I did. The AC system now works MUCH better.
[Re: 71muffin]
#2236316
01/17/17 10:07 PM
01/17/17 10:07 PM
Supercuda
About to go away
About to go away
up yours
I have my license so I can buy R12 for my 65 Cuda, assuming I ever put it back together. Problem is finding somewhere to buy it anymore.
[Re: Supercuda]
#2236327
01/17/17 10:16 PM
01/17/17 10:16 PM
DrCharles
West Plains, MO
I have my license so I can buy R12 for my 65 Cuda, assuming I ever put it back together. Problem is finding somewhere to buy it anymore. Yep, I got my Part 609 card too, about 20 years ago If you can find it, R-406a works even better and is a drop-in replacement for R-12. Still has 0.05 (compared to R-12) of the penguin-depleting potential, so it may have been phased out too.
[Re: 71muffin]
#2236335
01/17/17 10:25 PM
01/17/17 10:25 PM
Supercuda
About to go away
About to go away
up yours
Been about that long since I got mine as well. At the rate the Cuda is progressing those cans will rust thru and vent before I get the car back on the road, last time was 1998.
[Re: OzHemi]
#2236696
01/18/17 02:26 PM
01/18/17 02:26 PM
feets
Senior Management
Senior Management
Irving, TX
A Moparts member was kind enough to donate several cans of R12 to the Imperial when I got it running. We still have a functioning R12 machine at work so I was able to recover it when I had to pull the condenser.
