Re: Low oil pressure on rebuild
[Re: Interceptor72]
#2235614
01/16/17 09:44 PM
01/16/17 09:44 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You need a high volume pump. Some will say that's a Band-Aid but if it improves the pressure.............
[Re: Interceptor72]
#2235628
01/16/17 10:04 PM
01/16/17 10:04 PM
Posts: 11,798 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Before taking it apart? Cut the oil filter open for inspection. Oil an ultra light viscosity? HV pump. Ask the guy what clearances he used.
[Re: John_Kunkel]
#2235634
01/16/17 10:18 PM
01/16/17 10:18 PM
Posts: 4,457 Washington
madscientist
Washington
I agree, but we don't know the clearances or what grade oil the OP is using. It would be good to know that.
[Re: Interceptor72]
#2235641
01/16/17 10:22 PM
01/16/17 10:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
First ask the builder for the clearance specs then cut the filter open and see whats in there then I would ask what oil is in it... if its 10W30 or better put a high volume pump on it.. if it has 10w40 in it you should see 70 psi priming it with a 1/2" drill motor...super loose clearances will show low pressure.. make sure the pressure relief valve is tight
[Re: Interceptor72]
#2235650
01/16/17 10:35 PM
01/16/17 10:35 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Rocker shafts should have timed oiling from the #4 cam bearing. If someone grooved the bearing or cam journal, you might have too much oil feeding the shafts. Might need block restrictors.
[image][/image]
[Re: Interceptor72]
#2235661
01/16/17 11:01 PM
01/16/17 11:01 PM
MR_P_BODY
Did you put the rocker shaft on with the oil holes facing downward.. thats the load side and the way the factory does it.. there is a direction the oils should face but I dont know for a BB if thats inward or outward on the bottom but on factory shafts the "notch" was facing forward with the holes down.. the notch is on the front of the shafts them self... but it sounds like the flow is there to spray across the fender.. I've never had that happen even with 70psi so the shafts could be on wrong ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Interceptor72]
#2235677
01/16/17 11:23 PM
01/16/17 11:23 PM
RapidRobert
One thing I noticed about the rockers, is that when I primed the oil pump, I had the oil filler cap off. Oil from the rocker right under that hole went SHOOTING waaayy out over the fender and on the ground. never saw anything like that on any other motors I ave primed, but have never built a motor with shaft mounted rockers before. the problem is right there. undo it & see what's up. Keep us posted.
[Re: Interceptor72]
#2235680
01/16/17 11:28 PM
01/16/17 11:28 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
The first thing to try is easy and free, you have nothing to lose and it often solves the issue. Add a washer under the oil pressure relief spring in the oil pump cover.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: RapidRobert]
#2235682
01/16/17 11:31 PM
01/16/17 11:31 PM
Posts: 76 Florida
Interceptor72
One thing I noticed about the rockers, is that when I primed the oil pump, I had the oil filler cap off. Oil from the rocker right under that hole went SHOOTING waaayy out over the fender and on the ground. never saw anything like that on any other motors I ave primed, but have never built a motor with shaft mounted rockers before. the problem is right there. undo it & see what's up. Keep us posted. OK, I am going to flip the shafts and see what happens. I was also thinking of just putting the factory shafts and rockers on temporarily to just see if there is an improvement. The cam has .550 lift and I have beehive springs, so I think they should work in the short term and low rpms? Just to eliminate one variable...
[Re: Hemi_Joel]
#2235683
01/16/17 11:32 PM
01/16/17 11:32 PM
Posts: 76 Florida
Interceptor72
The first thing to try is easy and free, you have nothing to lose and it often solves the issue. Add a washer under the oil pressure relief spring in the oil pump cover. Yeah, I tried that (actually added a few just to see what would happen.) It did not seem to make any difference.
[Re: Interceptor72]
#2235684
01/16/17 11:34 PM
01/16/17 11:34 PM
madscientist
Washington
The first thing to try is easy and free, you have nothing to lose and it often solves the issue. Add a washer under the oil pressure relief spring in the oil pump cover. Yeah, I tried that (actually added a few just to see what would happen.) It did not seem to make any difference. If you shimmed the pressure relief and the pressure didn't go up with RPM there is a oil gallery plug missing, or some other giant leak.
[Re: krautrock]
#2235685
01/16/17 11:34 PM
01/16/17 11:34 PM
Posts: 76 Florida
Interceptor72
if it's a roller cam is it likely the cam journal is grooved for full time oil to the rockers?? Not that I recall.
[Re: Interceptor72]
#2235689
01/16/17 11:39 PM
01/16/17 11:39 PM
RapidRobert
I was also thinking of just putting the factory shafts and rockers on temporarily to just see if there is an improvement. Good plan, I would drill prime it (CCW) as is right now with a variable speed drill/5/16 hex rod with the valve covers off & no way you wont see where the leak is with a geyser of that magnitude.
[Re: madscientist]
#2235693
01/16/17 11:45 PM
01/16/17 11:45 PM
MR_P_BODY
The first thing to try is easy and free, you have nothing to lose and it often solves the issue. Add a washer under the oil pressure relief spring in the oil pump cover. Yeah, I tried that (actually added a few just to see what would happen.) It did not seem to make any difference. If you shimmed the pressure relief and the pressure didn't go up with RPM there is a oil gallery plug missing, or some other giant leak. This is what I'm starting to think ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
