Stroker OD mpg?
#2235623
01/16/17 09:58 PM
01/16/17 09:58 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Yeah, one of these things is not like the others.
Does anyone run a mild/moderate B/RB stroker build with an OD? If so, how bad did the increase in cubes kill the mpg?
Re: Stroker OD mpg?
[Re: feets]
#2235945
01/17/17 12:28 PM
01/17/17 12:28 PM
feets
Senior Management
Senior Management
Irving, TX
The reason that I ask is that I'd love to have the added torque of a stroker but the purpose behind the Imperial is road tripping. With the 440/727/3.23 and a loaded weight of 5500+ lbs that beast was getting 13 mpg at steady highway speeds across flat land. Get into the mountains and I'm sure it'll drop into single digits.
At these low mpg numbers small differences add up.
Re: Stroker OD mpg?
[Re: feets]
#2236013
01/17/17 01:56 PM
01/17/17 01:56 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
in your case I would look into a 383 stroker. you don't need cylinder volume, just lots of stroke for tons of torque. keep the bore small, use higher compression, some aluminum heads. personally I wouldn't shy away from headers and a small 2.5" exhaust with good mufflers. and a small hydraulic roller cam, add some roller rockers. and your good.
if you really want to get into it, add so dry film lube to the piston skirts, keep your oil pressure on the lower side with a stock volume pump and limit it to 60 psi. roller timing chain
I don't know if a 727 is your best option here, might want to consider at least a gear vendors or a 518 conversion. i'd leave the 3.23 gears. and efi definitely efi.
Re: Stroker OD mpg?
[Re: feets]
#2236035
01/17/17 02:43 PM
01/17/17 02:43 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
Feets, that is an interesting concept. I doubt many build stroker big blocks to improve gas mileage, it might be hard to find someone that has done what your looking for.
Pure speculation, I suspect the stroker with an OD is going to fair a bit better then the 440, 727, 3:23 will, for mpg, if both were driven the same. The added torque of the stroker to get the mass moving, and for a temporary pull on a hill to maintain the speed should be well offset by the reduction in rpm over the long haul. I don't believe the added cu in to feed will have that much impact given the weight of the Imperial, but I'd probably go for a smaller cu in stroker rather then a larger one.
I kind of picture it like what a 383 in that Imperial would do for mpg compared to the 440. The 440 likely would get better mileage over the smaller 383 because of the torque required to get the thing moving and keep it moving. Gene
Re: Stroker OD mpg?
[Re: feets]
#2236047
01/17/17 03:05 PM
01/17/17 03:05 PM
Posts: 4,412 Michigan
MarkZ
Worthy
Worthy
There was a magazine article a few years back where a guy built a stroked BB in a C body wagon for long road trips. For the life of me I can't find the damn thing. It was a real interesting build.
What is your timeline? I'll have a mild 512 in my car with a 518 behind it come Spring.
Re: Stroker OD mpg?
[Re: feets]
#2236067
01/17/17 03:22 PM
01/17/17 03:22 PM
feets
Senior Management
Senior Management
Irving, TX
A stroker is not for efficiency. It is for power. EFI and OD is for efficiency.
I have a 518 that needs to go in the Imp. It will get a FITech system too.
As for the long stroke making cheaper power, I think that's not quite right.
To get better mpg you need better engine efficiency. Heavier rotating mass is not the way to go. That being said, the B/RB platform is far from the model of efficiency. I'm not sure which way would make it more efficient with a given amount of fuel.
While I like the idea of a large engine working lightly more than a small engine working harder it comes down to balancing construction cost, performance, and operating cost.
I, too, plan on having this done before summer rolls around.
Re: Stroker OD mpg?
[Re: feets]
#2236423
01/17/17 11:51 PM
01/17/17 11:51 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I have a 68 Charger 512,a518 overdrive.3.54 gear, Holley carb,I have gotten 15 mpg @ 70 mph driving VERY easy.
Re: Stroker OD mpg?
[Re: feets]
#2236505
01/18/17 01:46 AM
01/18/17 01:46 AM
Posts: 2,255 IL
furious70
IL
are you doing a long arm rather than an octopus now?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Stroker OD mpg?
[Re: DrCharles]
#2236546
01/18/17 02:41 AM
01/18/17 02:41 AM
CSK
Pattison Texas
Lack of vacuum advance really kills light-throttle cruise mileage. Timing should be more like 48-50 degrees for that, instead of 34... I do have vac advance & have spent many hours tuning with a wide band. adjustable IFR & adjustable air bleeds are your friend !!!!!
Re: Stroker OD mpg?
[Re: furious70]
#2236701
01/18/17 02:32 PM
01/18/17 02:32 PM
feets
Senior Management
Senior Management
Irving, TX
are you doing a long arm rather than an octopus now? I don't know what I'm doing. That's what makes it fun.
Re: Stroker OD mpg?
[Re: CSK]
#2236702
01/18/17 02:34 PM
01/18/17 02:34 PM
feets
Senior Management
Senior Management
Irving, TX
Lack of vacuum advance really kills light-throttle cruise mileage. Timing should be more like 48-50 degrees for that, instead of 34... I do have vac advance & have spent many hours tuning with a wide band. adjustable IFR & adjustable air bleeds are your friend !!!!! After that much effort I'd go to EFI and let it tune itself.
Re: Stroker OD mpg?
[Re: feets]
#2236728
01/18/17 03:23 PM
01/18/17 03:23 PM
Posts: 3,428 Dandridge TN
Dabee
Dandridge TN
Lack of vacuum advance really kills light-throttle cruise mileage. Timing should be more like 48-50 degrees for that, instead of 34... I do have vac advance & have spent many hours tuning with a wide band. adjustable IFR & adjustable air bleeds are your friend !!!!! After that much effort I'd go to EFI and let it tune itself. 👍 What I did.
Re: Stroker OD mpg?
[Re: furious70]
#2236780
01/18/17 04:43 PM
01/18/17 04:43 PM
MarkZ
Worthy
Worthy
are you doing a long arm rather than an octopus now? Would an octopus with longer arms still be considered an octopus?
