Re: Why so few Procharger Mopar builds?
[Re: 70VcodeCoronetRT]
#2235362
01/16/17 03:43 PM
01/16/17 03:43 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Cost is huge and turbos make more power. There are a few fast procharger guys that don't hang out here also..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
#2235379
01/16/17 04:03 PM
01/16/17 04:03 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Turbos are the future. For what a procharger costs you can build a nice turbo system. No belts to worry about or huge mounting system.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2235394
01/16/17 04:17 PM
01/16/17 04:17 PM
Posts: 4,457 Washington
madscientist
Washington
Turbos are the future. For what a procharger costs you can build a nice turbo system. No belts to worry about or huge mounting system. IDK about the tube being the do all be all end all. If you google it, you can find Daddy Daves dyno test of his new Procharged engine. I forget what it made for power but it is impressive. And IIRC, it was on a 750 carb. I could be wrong on that, but that's what I recall. Can't wait to see it run, and since I don't sniff the air for every fart the SO guys do, DD may have already made some passes with it.
#2235403
01/16/17 04:30 PM
01/16/17 04:30 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I am not a Race guy - so take my comment for what it is. I think the procharger kits have issues with the serpentine belt slipping in some applications and "ready made kits".
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: DrCharles]
#2235418
01/16/17 04:52 PM
01/16/17 04:52 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
IMO The average mopar cheapskate wouldn't put the money into one. purple shafts and ss spring mentality is the norm Forget about a procharger or F.I. Why is not having more money than Sam Walton such a negative thing? Purple shafts and SS springs work and are cheap. Truth, and offended cheep skate 😂
#2235429
01/16/17 05:01 PM
01/16/17 05:01 PM
Posts: 1,705 Nebraska
70VcodeCoronetRT
Nebraska
I would love to go turbo. But not being a fabricator it's really not as practical for me as a bolt on Procharger. Plus I got a smoking deal on a Supercharger store setup with a F1R Procharger. I sent the F1R back to Procharger to have them make sure it was good to go. Now just need to have a killer short block built. And wait and see what the Trickflow 270 heads will be like. And research, research, research.
[Re: CTD5.9]
#2235436
01/16/17 05:09 PM
01/16/17 05:09 PM
madscientist
Washington
The biggest issue is like everything else Mopars are not a big market. So the brackets/kits will be more expensive or non existent requiring people to fabricate their own. If that is what you want, build it! Don't let the people mocking "purple cams" and crap on here lead you away. Talk to the company or companies you want to purchase the procharger from they will have done a big block Mopar. Steve Morris Engines has a few on their youtube channel as well, but they might be a bit more then 10's unless your car weighs 8000lbs Double AMEN to this. If you want it, do it.
#2235441
01/16/17 05:18 PM
01/16/17 05:18 PM
Posts: 4,209 New York
polyspheric
New York
Positive: lower underhood temperature than turbo hood clearance (unlike 6-71 etc.) can use intercooler (unlike 6-71 etc.) Negative: low torque at low RPM still need a complete header system less power than a turbo with same boost
Boffin Emeritus
#2235445
01/16/17 05:26 PM
01/16/17 05:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The reason you don't see many Pro-Charged Mopars, is because there are few kits for Mopars, especially for the bigger blowers. The way Mopar engine compartments are, it is nearly impossible to put a charger on most of them, because there simply isn't room. So lack of kits, leaves most of them custom installs, but still doesn't mean the problems go away. A big blower on an early Mopar muscle car, nearly guarantees some inner fender mods and custom brackets. And a bigger motor is going to need a bigger blower regardless of power. A small blower is a cork on a larger motor and will actually hurt the power. Inner coolers or heat exchangers are hard to package in there as well. Most Mopars have little room in the front of the cars
Direct drive is always an option, but that's generally a race only deal
[Re: polyspheric]
#2235468
01/16/17 05:43 PM
01/16/17 05:43 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Positive: lower underhood temperature than turbo hood clearance (unlike 6-71 etc.) can use intercooler (unlike 6-71 etc.) Negative: low torque at low RPM still need a complete header system less power than a turbo with same boost I have a SB set-up in the works currently, I went this direction because, I felt the tuning/learning curve would not be as intense, the lower torque is, as I see it, a plus for a road race track toy, a simpler exhaust saves a lot of headaches, and was thinking the power delivery will be more predictable and consistent, other then that, I would have gone turbo. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: jcc]
#2235492
01/16/17 06:30 PM
01/16/17 06:30 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
There is a Pro-Charged late Charger here in Tacoma and he was a member of the Mopars Unlimited Tacoma Chapter. I still send him the newsletter. He likes to race and runs consistent low 12s with his street car. I will send him a link to this thread.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#2235510
01/16/17 07:08 PM
01/16/17 07:08 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You have already bought it, so this info may be a bit late. If buying a new blower, I would suggest vortec. Procharger will not sell as much as a seal to an end user. You are at their mercy when something goes wrong(and things do) during race season, if you're not sponsored by them, you wait and wait and wait. If they sold parts you could at least repair your own stuff in a timely manner. My friend sent in his procharger for a leak. It took 6 weeks to get it back. He makes one pass and the thing eats itself up. They forgot to tighten the impeller nut and the wheel chewed up everything. They fixed it junk yard style with a used volute, and a new wheel. Got it back 8 weeks later. Sold it after swearing to never buy another one from them.
