Re: Dana rear gears...
[Re: JohnH]
#2231986
01/11/17 12:10 AM
01/11/17 12:10 AM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
Don't think so. I've only seen 3.54 for danas.
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
[Re: Diplomat440]
#2232322
01/11/17 04:04 PM
01/11/17 04:04 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Dana 61 3.07 gears can be used in the Dana 60 by using the 3.54-4.10 differential and removing material from both the ring gear and the differential flange where the ring gear mounts....some even remove material from the bearing flange to move the differential over. Sources for the gears listed below:
FORD REARS
603438-6 F-250 1974-75
603713-5 603714-1 603540-5 603899-1 1976-78 F-250 4X2
603594-19 1975-78 E-250 (VAN)
603925-1 1979 F-250 4X2
603932-7 1979-80 E-250
603946-1,2 1980-81 F-250 SEMI-FLOAT 4X2
605022-10,12 1981-83 E-350 DRW CHASSIS
605039-5 1981-83 F-350 CHASSIS
[Re: dvw]
#2233673
01/13/17 07:37 PM
01/13/17 07:37 PM
John_Kunkel
Rio Linda, CA
On the off chance there are some old stock Dana 61 gears still floating around, here are the Ford numbers I have:
For the 3.07
D8TZ4209F D0TZ4209E
For the 3.31
D8TZ4209D D9TZ4209B
