Re: SB heads
[Re: Racer33]
#2231861
01/10/17 09:33 PM
01/10/17 09:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you cant go with W-2s.. change over to Magnum heads and intake.. but if its just the intake height you could mill the W-2 intake down
Re: SB heads
[Re: Racer33]
#2231884
01/10/17 10:16 PM
01/10/17 10:16 PM
MR_P_BODY
I'm not against w2 but our intake rule is 4-1/2 or 4-3/4 inches above the block. Do they make an intake like that for W2? Thhey would be nice to have that good of a head to put on a better short block down the road but rockers,headers and intake would kill my budget. Mr.P don't you have some W2's laying around? I have some gen 3 hemi stuff. I would have to look around.. I know I have 1 extra but havent found the other one.. I'm sure its here somewhere.. could be in the wifes garage... but I am leaving for vacation in a few days and wont be back for a while EDIT they would be the standard length valve econo ones.. I am running the long valve ones on my 416
Re: SB heads
[Re: Racer33]
#2231886
01/10/17 10:18 PM
01/10/17 10:18 PM
Posts: 4,457 Washington
madscientist
Washington
I have a W-2 Strip Dominator in the shop.
If I can get into the shop tomorrow I will go take an measurement and tell you how tall it is. If it keeps snowing I may not be able to get in there without some digging.
Re: SB heads
[Re: Racer33]
#2231906
01/10/17 10:35 PM
01/10/17 10:35 PM
RapidRobert
that'd be my suggestion. glowing reports from users. I have a set unused as of yet & they look real nice. I got a good deal from importer Eric haugland in Las Vegas
Re: SB heads
[Re: Racer33]
#2231917
01/10/17 10:45 PM
01/10/17 10:45 PM
MR_P_BODY
Mr.P econo heads wouldn't be bad. I'm in no big hurry if you have a chance to find them let me know. Maybe some gen 3 hemi trade? I know you snowbird so it will be awhile. I'll look... also I might still have a set of rocker arms for them... how big of a cam are you thinking
Re: SB heads
[Re: MR_P_BODY]
#2231930
01/10/17 11:02 PM
01/10/17 11:02 PM
Posts: 179 Norfolk, NE
Racer33
Norfolk, NE
Right now I'm running .506 intake and .513 exhaust. That's assuming the 1.5 rocker ratio. May go bigger if I put a better short block together. Are W2's worth bolting on without doing some port work?
Re: SB heads
[Re: Racer33]
#2231960
01/10/17 11:40 PM
01/10/17 11:40 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Just measured a W2 Strip Dominator. Straight edge across the carb flange. 4 1/2" @ Front / 5 1/2" @ Rear. Hope this helps.
[img] [/img]
Re: SB heads
[Re: clonestocker]
#2231967
01/10/17 11:48 PM
01/10/17 11:48 PM
madscientist
Washington
Just measured a W2 Strip Dominator. Straight edge across the carb flange. 4 1/2" @ Front / 5 1/2" @ Rear. Hope this helps. Obviously no snow in Tuscon!!!! I didn't think it had 1 inch of taper though.
Re: SB heads
[Re: Racer33]
#2231979
01/11/17 12:03 AM
01/11/17 12:03 AM
madscientist
Washington
I looked and the rules say 4-1/4 but it doesn't say how to measure other then to the block surface. Any room to mill the carb flange? Damn, a quarter inch off of the plenum is one thing but to get an inch and quarter off would be tough. I used to build some circle track stuff, even went to some rules meetings. Almost always went to a fist fight, because the rules to save money generally don't save money but really cost money. So I just learned to deal with the rules but God knows I hate 2 bbl rules, cast iron head, intake, exhaust rules and most rules to keep costs down.
